My BS9000 will play all 6 cds from 1 to 6 no problem. if I choose to start on cd 2, it will play a track and then change to cd 3 without being prompted. Almost like its on random but its not. When misbehaving its not posable to call another track on the same cd.
Any ideas ?
valve1:Any ideas ?
Are you sure that the "Random" is not on? Sometimes I had the Random on, even if I did not choose it!...
Samsung PS64F8500, Beosound 9000, 2 x Beolab 1, Beolab 7-4, Beolab 2, 2 x Beolab 4000, Beolab 3500, 2 x Beo 4, Emotiva UMC-200, Oppo BDP-103D, Panasonic DMR BCT-730; Harmony Ultimate.
Problem sorted. I played the 9000 on random for a few hours then turned the random off.
Glitch gone !
