Beocom 2 (old and new)
Andyab1967
Posts 2
Andyab1967 Posted: Sat, Apr 19 2014 1:45 PM
Greetings all,
any of you had luck getting old Beo2 to work iwth new ones? Here is my situation. I had 3 Beocom2 with a base station and move to Dubai. I had them converted and are working just fine. I ended up buying two more handsets but the handsets are the newer model (not the same model as the US) and i am unable to make them register to the old base station and i can't get the old ones to register to a new base station. i need to have two base stations due to the fact that the range of the base station does not cover the area of my apartment (concrete walls). Would be grateful for any suggestions.
Andy
valve1
The south of France and occasionally Dublin Ireland
Posts 1,502
valve1 replied on Sun, Apr 20 2014 8:17 AM
Hi , sounds like you have mk 1 and mk11 which I believe will not work with each other.
Perhaps someone has a way around this ?
Andyab1967
Posts 2
Andyab1967 replied on Sun, Apr 20 2014 11:55 AM
I sure hope there is an answer to this. I spent an arm and a leg on these because i love them. I just hope B&O are not going to leave their fans stranded like this.
Page 1 of 1 (3 items) | RSS
