Hi can anyone tell me if the black cloth on the beovision 6 22 can be replaced with a metal beovision 6 23 ? Are the speaker frets same size ?
JONNIE: Hi can anyone tell me if the black cloth on the beovision 6 22 can be replaced with a metal beovision 6 23 ? Are the speaker frets same size ?
The 6-23 fret is wider than the 6-22, although the depth top to bottom is similar.
The 6-22 is a push-on fret, whereas the 6-23 clips on with a sideways sliding movement.
You could cut a 6-23 to length and bond the metal face to the plastic 6-22 rear fret support, but there is a small unperforated edge area right around the 6-23 fret so it probably wouldn't shorten and look right.
Graham
Thanks so much would love to try it just due to my living room colours you have been so helpful was hoping it would be the same only metal but did wonder about size difference !
