Hi all!
I am trying to figure out what is causing the sound to be "inside out" in my setup.
By inside out I mean it sound like the voice or the instrument that should sound up front is in the back, as if you imagine standing backstage listening to a concert. I believe its called a "phase error", as when you connect ordinary passive speakers the wrong way. ( which can't be done with beolabs, right?)
My setup: front speakers BL 8000, rear BL 6000 connected to a BV3-32 and bs2300 and Apple TV v1.
Of course when using "speaker 5" mode it will sound weird when playing 2 channel stereo, but even when using "speaker 2" or "speaker4" it is the same. It is more prominent when playing Mp3 through my Apple TV but listening to the same MP3 through Headphones works perfect.
I have of course double checked the connection from the Apple TV to the BV3 that the red and white stick is properly connected to the right connector on the scart ( RCA to Scart adaptor)
Any ideas how to make the sound more "present" ?
Thanks,
Peter
---------------------------------------------------------------------------------------------------------------------------------Beovision 7-40 Mk VI, Beovision 3-32, Beovision AV9000, Beovision AV5, Beolab 8000, 6000, 5000, 3000, 2000, Beocenter 2300, 9000, Beocenter 2, DVD1, DVD2, Beogram 3300, LC2, Beolit 12, 3 x AppleTV
