Hello, I can't switch to tape on my Beocenter 4000. I've tried to put new switch but it don't works. What can be problem? Thank You
Hello
have you check wiring from connectors and pcb?
Marco
Which version of Beocenter 4000 do you have, one deck or twin deck ?I take it, you are trying with a tape loaded ?Are there no reaction at all ?
