just got a CDX in excellent condition, everyting is fine except one of the track number and the readout change button need a lot of pressure to get them to work, the others are absolutely fine. Is there an easy solution to this at all?
thanks in advance
Paul
Under each touchpad is a cylindrical conductive rubber spacer establishing connection from the backside of the glass to apin on the underlying circuit board. Sometimes, the conductive properties between the rubber and the pin "disappear"and it can be necessary to rearrange the rubber a little so the pin will press on a different area of the rubber surface.
That's brilliant Martin! Sounds pretty simple, thanks so much for the advice 😃
