Beosound Core 2020 and High Resolution on Airplay2
This post has 16 Replies | 1 Follower
seethroughyou
UK
Posts 999
seethroughyou Posted: Tue, Mar 31 2020 2:16 PM
1.
I am considering getting a Core and wondered what fellow Beoworlders make of it several years down the line? Is it an enjoyable, mature and reliable product?
2.
Does anyone know if Airplay2 handles 24bit, 96-192khz files if I were to stream them to the Core? It’s not critical but helpful to know when deciding to go with a more pricey classical music streaming plan that offers genuine high resolution material or not.
Thank you.
Present: BL90, Core, BL6000, CD7000, Beogram 7000, Essence Remote.
Past: BL1, BL2, BL8000, BS9000, BL5, BC2, BS5, BV5, BV4-50, Beosystem 3, BL3, DVD1, Beoremote 4, Moment.
Carolpa
Posts 1,700
Silver Member
Carolpa replied on Tue, Mar 31 2020 2:53 PM
seethroughyou:
1.
2.
Thank you.
1. My BS Shape works without any problems at my satisfaction.
2. To my knowledge, Airplay only supports up to 48kHz.
Jaffrey2230
Washington DC
Posts 520
I use the Core exclusively for AirPlay 2 with no complaints. I have also used it with an Apple TV 4K connected to TV for video and Core playing the audio in another room and the sync was perfect. I also have it in wireless mode (I have good all house wifi coverage with Google Mesh).
AirPlay 2 is 16bit/48khz. I believe you can stream Hi Res from the B&O App if you like (I haven't tried it). In my case I switched from AirPort Express to Bluesound Node 2i to the Core primarily because of the audio quality. Connected to my Beolab 11 and Beolab 6000 speakers the audio sounded clearer with a little more defined bass. Not sure if it was because of the DAC in the Core or because you can set it to the right speaker type in the B&O App and the sound is then optimized for the speaker. Anyway, I really like it.
B&O in my life 😊:
  • Beolab 8002 + Beolab 2 + Beosound Core with Essence Remote (Office)
  • Beolab 6000 + Beolab 11 + Beosound Core with Essence Remote (Bedroom)
  • Beoplay A9 Mk2 (Living Room)
  • Beosound 1 with wireless dock (Portable)
  • Beosound Balance (Dining)
  • Beoplay H95 (Focused listening, travel)
  • Beoplay H9 (3rd gen) (retired)
  • Beoplay P6 (Portable)
  • Beotime wall clock (hallway entrance)
  • BMW X5 50i with B&O Audio Package (Commute/drive)
Razlaw
Posts 4,345
Razlaw replied on Tue, Mar 31 2020 4:29 PM
seethroughyou:
1.
Thank you.
Mine is. Works great and very reliable. Was planning to buy two more to update a couple rooms that are still on Masterlink, but have decided not to now that MultiRoom is being discontinued.
Duels
England
Posts 2,553
Duels replied on Tue, Mar 31 2020 4:45 PM
I’ve had a core for the last 15 months or so.
Initially I found I had to restart it from time to time as things seemed to freeze occasionally. (Perhaps once a month)
But for the last 9 months or so it has been completely stable.
I use it for tunein radio and and streaming Spotify to my BL18s and 19.
The essence remote is a nice way to interact with the core too.
I would happily recommend the core.
trackbeo
Posts 644
trackbeo replied on Tue, Mar 31 2020 5:20 PM
@Carolpa or @Jaffrey2230, what is your source for "AirPlay 2 is 16bit/48khz."?  I have not seen any straightforward answer from Apple about the protocol, nor from B&O about the device.  An Apple TV only supports 48kHz, sure.  But others?  (Edit: Sorry, perhaps you meant that a Core *VIA* Airplay2 is 16-bit/48kHz?  If so, the question is how you figured that out?)
There are 3 separate issues:  (1) Does the sending device send that particular sampling & bit-depth data stream?  It seems to depend on both the device and the application running.  (2) Does AirPlay2 the protocol support it?  (3) Does the receiving device even support inputting the stream at that rate, and if so, does it internally down-sample it before (or in) its DAC?  The most clear and declarative answer I have seen -- see post #33 in the thread below -- is unsourced, alas:
https://audiokarma.org/forums/index.php?threads/notes-on-chromecast-airplay-and-hdmi.892495/page-2
seethroughyou
UK
Posts 999
Well I’ve just read the following thread:
https://archivedforum2.beoworld.org/forums/t/31004.aspx
Naturally, I’m now cautious about spending £600 only to find it doesn’t work as originally advertised a few years from now. stories like the above don’t inspire confidence...
Sandyb
Posts 2,186
Sandyb replied on Sat, Apr 4 2020 10:59 AM
seethroughyou:
Why not just get a third party streamer, with Airplay and or Roon capability too?
B&O just don't seem capable or willing to offer a fuller featured digital transport these days
seethroughyou
UK
Posts 999
Sandyb:
Do you know of any third party streamers that would also trigger Beolabs to wake up?
Carolpa
Posts 1,700
Silver Member
Carolpa replied on Sat, Apr 4 2020 11:29 AM
seethroughyou:
why spending this amount on a mkI
You are better if with an mkII or Core
Sandyb
Posts 2,186
Sandyb replied on Sat, Apr 4 2020 1:04 PM
Wired or wireless?
Wired - many streamers have a variety of outputs that will work into BL3'S, from what I can see.
The same goes for streamer /DAC units too.
seethroughyou
UK
Posts 999
Sandyb:
Wired or wireless?
Wired please.
Jaffrey2230
Washington DC
Posts 520
I have tried AirPort Express and Bluesound Node 2i and Beosound Core with my Beolab systems. Not only does the Core work very well with AirPlay 2 but the audio was better than the other two - interestingly both the Node 2i and the DAC in the last gen AirPort Express are supposed to be pretty good. Yes, if you need to use Roon then go another route, but for AirPlay 2, you won't be disappointed with the sound quality and performance of the Core. Just basing this off of my experience.
B&O in my life 😊:
Sandyb
Posts 2,186
Sandyb replied on Sat, Apr 4 2020 6:01 PM
I dont have a list for you per se.
A shortcut to endless googling might be the Roon website - and click the link for Roon partners.
Theres a pretty big section on Roon tested Network players, listed by manufacturer.
From there you can see a broad range of what is out there, and look at product specs on the brand website.
Many Beloabs will accept analogue outputs as well as digital ones, and quite a few of the network players I've looked at have both outputs.
For me, this is a good starting point, as I'm likely to get a Roon server and Roon ready network player - pump this in to one of my B&O systems, and as they're all NL, will be able to go multi room from there. But the main reason is that using single apps, be it Spotify, Tidal or whatever (or the B&O app) is incredibly unsatisfying to me, as music listening experiences go, and I want the Roon UI / cataloguing / integration of my NAS music.
Theres no point waiting for B&O to produce an audio master or new audio platform (whatever that means) - there's a gold standard already out there in Roon, and B&O wont get anywhere near that.
seethroughyou:
Sandyb:
Wired or wireless?
Wired please.
seethroughyou
UK
Posts 999
Hi Sandy,
That’s very good of you. Thank you for the distillation of your experience and wisdom.
Yes, Roon is phenomenal but it’s tied into Tidal or Quboz neither of which I have any interest in being a classical listener. I am also moving away from music on my NAS which is very limited. It’s a shame that Apple don’t make an Airport Express capable of Airplay2.
Jaffrey2230
Washington DC
Posts 520
You could get an AirPort Express off of eBay for around $50 now. It’s the best value steamer for AirPlay 2 by a long shot. I had one in my system for a long time and many of my friends still use it. In my experience the audio quality is excellent with the only downside being that it only supports AirPlay 2 and you can’t connect any other source like you want with the Core. It is a pity Apple stopped making it since it is a rock solid product.
B&O in my life 😊:
trackbeo
Posts 644
[Misunderstood.  Deleted.]
Page 1 of 1 (17 items) | RSS
