Dear all, hope this post finds you well.
I am currently trying to find a way to use the existing VHS and connect it with a Scart to RCA plug into a new Smart TV that will be placed on the frame of the old B&O. Have any of you done this project successfully in the past?
I am also keen in using the existing speakers that are built in the BeoVision Avant and connect them through aux to the new Smart TV. Are there any suggestions for this?
Thank you all in advance :)
