The tone arm on the Beogram 3000 doesn't rest all the way to the right and because of this doesn't start playing records at the beginning. When it reaches the end of the record, it doesn't return to the start position automatically and I have to hit the stop button to make it do so. Anyone know any solutions?
Beogram 3000 5903 with MMC-3
Beomaster 3000 2933
Beovox RL 140's
All tonearm adjustments are explained in the service manual, with diagrams - set down point adjustment etc. It's too complicated to try to explain as there are several cams to adjust and the correct screws need to be undone to do some of it.
If you upgrade to Silver or Gold, the service manual is available to you.
Dave.
Dave Farr: All tonearm adjustments are explained in the service manual, with diagrams - set down point adjustment etc. It's too complicated to try to explain as there are several cams to adjust and the correct screws need to be undone to do some of it. If you upgrade to Silver or Gold, the service manual is available to you. Dave.
And a gold membership will get you into the PrizeDraw tomorrow
