Hello.
Can someone please tell me if a set top box (that works with a beo 4) is still available.
Mine has shat itself. I cannot get half the channels, a $40 one can on the same aerial.
Of course you can connect a cheapie, but then you need another remote.... Arggghhhh!
Missing my favourite channels. (Spell check is saying I have spelt favourite wrong, is it me, or AmeriCAN spelling, getting old....??)
Cheers....
PLEASE........ Grrrrrrr!!!
UK probably different, but best thing to do is to go through the STB list on your BV5 and either look for something second hand on eBay (quite a lot over here due to individuals upgrading from Standard Definition), or maybe take a chance on a box like Humax (if in your list) where they tend to keep the same codes for later boxes.
Or ask a dealer about what is on the latest / last BV5 module and think about a chip upgrade..... although there is every possibility that all the listed STB's are out of date by now.
Graham
Thank you Graham.
Much appreciated.
