Hi Guys,
I can't for the life of me remember what button/s to press to get the heads to move into the play position without a tape installed in order to clean them.
I've done the usual google searching and checked the forums but I can't seem to find the info. I've managed to find out how to do it on a 5500 (press and hold stop and press play) but that doesn't work on the 5000.
Thanks in advance,
Lee
Hold STOP while pressing PLAY.In autoreverse decks (= not Beocord 5000) pressing TURN then switches the active pressure roller.When done, press STOP.
That doesn't seem to work here Martin, I'm sure it worked in the past... but I honestly thought it was a different combination of buttons....
Anyone with a becord 5000 to hand want to check theirs?
I've tried holding down stop then pressing play. Tried holding play and then pressing stop... tried holding stop and pressing all the buttons but nothing seems to engage the heads.
Can anyone else try theirs and see if they can get it to work?
Any beocord 5000 owners out there willing to give it a try?? Pretty please ;-)
Dom
2x BeoSystem 3, BeoSystem 5000, BeoSystem 6500, 2x BeoMaster 7000, 2 pair of BeoLab Penta mk2, AV 7000, Beolab 4000, BeoSound 4000, Playmaker, BeoLab 2500, S-45, S-45.2, RL-140, CX-50, C-75, 3x CX-100, 3x MCL2 link rooms, 3x Beolab 2000, M3, P2, Earset, A8 earphones, A3, 2x 4001 relay, H3, H3 ANC, H6, 2014 Audi S5 with B&O sound, and ambio
Probably just me getting old.The procedure I described above is indeed for the Beocord 5500 etc.There doesn't seem to be a similar procedure fo Beocord 5000.
Thanks for giving it a try Dom.
And Martin, the strange thing is I remember doing it on the 5000 not long after I got it. I can't remember what I had to press but it was different from the 5500 that's for sure. Im sure I read the instructions on the web somewhere but for the life of me I can't find it.
Thanks again,
