faulty beocenter 2
philippebouquet
Posts 5
philippebouquet Posted: Mon, Jan 20 2014 11:43 AM
I have 2 questions on the beocenter 2
1: I cannot enter the service mode ( using the sequence in the service manual ( list >> 00 go or with the remote menu >> 00 go ) give me the same result: I here Nmusic and do not enter the service mode.Is there another way to enter the service mode or am I doing something wrong ?
2: on occasion the loading of the cd is faulty ...on the fist touch of the load "button", the doors slide open then a motor "buzz" is heard but the cd loading mechanism stay closed. On the second touch, the loading mechanism opens and closes immediatly while the illumination stays off and the display does not indication load CD..it does this ,i'd say , 9 times out of 10 .The 10th time it works fine: any suggestions ?
I am trying to do item 1 (enter the service mode) to adress item 2 ( faulty CD loading) so any advice on this second point will be much appreciated
thanks in advance
Philippe
Keith Saunders
Hampshire, United Kingdom
Posts 5,495
A Warm Welcome to Beoworld and your first posting
There are two ways to enter the service menu, either by using the keyboard or the Beo4 remote.
With Keyboard:-
  • With the BC2 switched on, press LIST then SETUP then press >> and within 3 sec. Press 0 0 GO
With Beo4 remote:-
  • With the BC2 switched on, press MENU then SETUP then press >> and within 3 sec. Press 0 0 GO.
Regards Keith....
Keith Saunders
Posts 5,495
Philippe,
Can you also please note that when you joined you provided an invalid email address. Can you please email me your correct email address, so that I can update the system.
Regards Keith....
dongkw
Posts 3
dongkw replied on Wed, Jun 25 2014 8:36 AM
hi
I have a BC2,DAB already.but set menu not display set item,only have AM FM tuner,why? how to seting ?
thank you very
email : dongkw@bbn.cn
Page 1 of 1 (4 items) | RSS
