Sound quality BL2500 versus BL4000 ?
This post has 19 Replies | 0 Followers
FranckF
Posts 93
FranckF Posted: Thu, Mar 13 2014 11:38 AM
Hi all,
I have a pair of BL2500 plug to my Ouverture. For the one who have chance to compare BL2500 versus 4000 did you noticed a really big difference ?
Thanks for your feedback
Franck
Millemissen
Flensborg, Denmark
Posts 14,680
Yes - I did!
Millemissen
Flensborg, Denmark
Posts 14,680
Yes - I did!
Edit - had to say it twice Stick out tongue
FranckF
Posts 93
FranckF replied on Thu, Mar 13 2014 12:09 PM
And ? very big difference ?
Thanks  !
Franck
kallasr
Germany
Posts 2,562
kallasr replied on Thu, Mar 13 2014 2:08 PM
Millemissen:
Yes - I did!
So did I!
Great Speakers, the Beolab 4000, and so many options to set them up: wall mount, floorstand, horiziontal table brackets, vertikal table brackets*
Ralf
*: actually, looking for the Standard table stands, so if anybody has them for sale...
Die_Bogener
Posts 192
Yes, there is a difference.
It's more or less the size of the speaker, bigger is better.
But also the electronic sound path, the 4000 has a little bit better electronic parts and design...
Both can be upgraded, pretty easy the BL2500, the 4000 a little bit more material. Both sound superb after the upgrade.
How? Look and find it in the old archieved workbench forum... everything you need :)
BO
Halmstad, Sweden
Posts 728
FranckF
Posts 93
FranckF replied on Mon, Mar 17 2014 11:35 AM
Hi and thanks both of you but really I'm sure to breake my speakers if I try to do so...
I nerver modified any electronic device so...
Anyway thanks for this good link, perhaps one day I will make the jump... or change to a BLxxxx I will see.
Have nice day
Franck
Steffen
Denmark
Posts 1,408
Steffen replied on Wed, Mar 19 2014 11:07 PM
If you have never modified any Electronics, then my advice would be:  don't try.
My answer to your first question is: The 4000's sound much better than the 2500's.
Jeff
USA
Posts 3,793
Silver Member
Jeff replied on Thu, Mar 20 2014 7:06 PM
I know the 4000's are supposedly active, in that they have two amps and an active crossover, but did the 2500s as well, or were they like the Pentas, amplified but using passive crossovers?
Jeff
robaer
Posts 23
robaer replied on Fri, Mar 21 2014 2:53 PM
I have the Beolab 2500. My dealer told me the were active with electronic filters and separate amplifiers for each driver. They are quite heavy for their size, so I don't doubt him.
Still the sound is nothing to write home about, almost like a pair of computer  desktop speakers. Which is not strange since the cabinets are almost completely made of plastic.
I've never owned the Beolab 4000, but I've listened to them numerous times. They sound more like a pair of real hifi speakers to me. Also, they look 100 times better IMHO.
FranckF
Posts 93
FranckF replied on Fri, May 9 2014 2:09 PM
Hello all,
To Robaer. Saying that the BL2500 is more or less than a computer speakers I would be curious which computer you have ! I agree with you those are not the best in class loudspeakers but :
1) Yes they are active speakers with dedicated class AB amplifiers for each "Bass/Medium" chanel and one for treeble
2) The power unit is very accurate (this explain the weight because of current transformer)
3) There is plastic and... plastic. Like for cars. In low cost brand there are plastic, in Aston Martin DB9 as well, but not the same. And not so sure the cabinet itself is plastic, it looks like much more metal because mine as a mark on corner if it was plastic it would be broken. To me is Zamac or if not Zamac at least a metal based of alloying elements.
I have a friend of mine who have "Cabasse" or "Triangle", "Kef" etc... speakers and sorry but ... no comment, mainly if we compare to the size !
Just to moderate a little on the sound quality of BL2500. I have beosound 9000 on Penta MK3 with Beolab 2 for bass, so I can also compare with a quite good configuration, and BL2500 are not that bad.
Cheers
Franck
mbee
Paris, France
Posts 1,842
mbee replied on Fri, May 9 2014 2:56 PM
BL4000's are in an other league, it's really better, even people with bad audition can confirm that. Then, BL17 are better than 4000, and then BL18's... Or BL20!! depending on the budget, you can upgrade with almost any Beolab, past or present (except BL4 or 6000)!
BO
Halmstad, Sweden
Posts 728
BO replied on Fri, May 9 2014 3:00 PM
I've tested BL2500 vs BL6000 in the same setup. In my ears the BL2500 outperformed the BL6000. Better bass!
//Bo.
A long list...
FranckF
Posts 93
FranckF replied on Sat, May 10 2014 8:53 PM
Hi all,
To mbee. Yes the budget THAT is the point otherwise... but with second hand you can get good items and till now no surprise with all I purchased.
To BO. I have One Ouverture that was plugged on one pair of BL6000 in one room and one Ouverture in bedroom with BL2500 (the one I would like to replace either by BL12 or BL3 see my post about BL12 sound quality). I don't know if it is because of the size of the room but I agree with you impressive how bass are deeper with the BL2500. More or equal to the 6000 on which I added finally a BL2... ABL component of the BL2500 does well its job... Now it is question of budget, the 4000 are cheaper versus the 3s....
Difficult to choose and the best is to be able to listen "on place" not only in shop...
Cheers
Franck
FranckF
Posts 93
Hi all,
Cheers
Franck
BO
Halmstad, Sweden
Posts 728
BO replied on Sat, May 10 2014 11:44 PM
Well, I dont know the BL3, but I have the BL4000 and they are better than both BL6000 and BL2500.
//Bo.
A long list...
DMacri
United States
Posts 881
DMacri replied on Sun, May 11 2014 1:11 PM
Has anyone had any success mounting BL2500 speakers on a floor stand?
Dom
2x BeoSystem 3, BeoSystem 5000, BeoSystem 6500, 2x BeoMaster 7000, 2 pair of BeoLab Penta mk2, AV 7000, Beolab 4000, BeoSound 4000, Playmaker, BeoLab 2500, S-45, S-45.2, RL-140, CX-50, C-75, 3x CX-100, 3x MCL2 link rooms, 3x Beolab 2000, M3, P2, Earset, A8 earphones, A3, 2x 4001 relay, H3, H3 ANC, H6, 2014 Audi S5 with B&O sound, and ambio
FranckF
Posts 93
FranckF replied on Mon, May 12 2014 11:07 AM
Hi BO,
Not the first time people encouraged me wity the BL4000 and better with their bass update in 4002 version... Cheaper than the 2 others (BL3 en 12)...
Thanks for your notice.
Franck
FranckF
Posts 93
FranckF replied on Mon, May 12 2014 11:09 AM
Hi Dom,
Appart the full wall stand to mount the entire Ouverture + 2500 on wall I don't know about  any floor stabd for such speakers or to do it by yourself but take care about "material" component to use for in order to not disturb sound...
Cheers
Franck
Page 1 of 1 (20 items) | RSS
