Sharing BeoLink speakers with television option 5?
This post has 10 Replies | 2 Followers
Cornelius
Posts 28
Cornelius Posted: Tue, May 13 2014 9:01 AM
In my bedroom I have a BeoVision 10 '46 installed and a BeoLink passive with IR eye and loudspeakers connected to it. All is connected with each other via MasterLink.
What I want is to be able to listen to music from the audio master in the living room over the speaker one hand and also be able to have the sound of the bedroom television over the loudspeakers. So I've set both devices in the bedroom to option 5.
But it seems I can only have music from the living room over the speaker, no television sound. Any suggested what I'm doing wrong? Is what I want possible at all with the current setup?
Raeuber
Germany
Posts 2,542
Raeuber replied on Tue, May 13 2014 9:17 AM
Sorry, but this is not possible. Beolink passive can only pick up the sound from the master, not from link TV.
Greets
Räuber
Millemissen
Flensborg, Denmark
Posts 14,680
Why do you want 2 (!) Linkroom products there.
Why not just connect the BL Passive as an amp for the speaker, you already have connected to it.
Only thing you need is a PowerLink cable from the tv to the BL Passive. And you would not need the ir-eye anymore.
This way you can easily have either sound (through the internel and/or the external speakers) from the master room or from the tv itself.
Cornelius
Posts 28
Cornelius replied on Tue, May 13 2014 9:40 AM
Thanks for that info. Disappointing though, I had hoped the BeoLink passive would behave just like a BeoSound with ML.
Cornelius
Posts 28
Cornelius replied on Tue, May 13 2014 9:41 AM
I would be fine with just using the TV as link product, however, even in option 6, it doesn't play link radio from the living room.
stefan
200 miles from Struer
Posts 2,920
stefan replied on Tue, May 13 2014 9:59 AM
Do you have another BV in yor setup?
What is your audiomaster?
Assuming you have listed all devices in your ML system try:
audiomaster livingroom A.OPT 2
videomaster bedroom BV10 V.OPT 1
BL passive bedroom L.OPT 5
to get BV10 sound to BL passive press AV-TV (DTV, DVD....)
hope this helps
Stefan
Cornelius
Posts 28
Cornelius replied on Tue, May 13 2014 10:06 AM
There is a BV11 in the setup and a BeoSound/Master 5 (option 2) in the setup. Both in the living room. In the study there's also a BeoSound 3000 in option 6.
Since I already have another VideoMaster in the setup, I guess I cannot put the bedroom BV10 in option 1?
stefan
Posts 2,920
stefan replied on Tue, May 13 2014 11:03 AM
Correct - unfortunately...
Is your BV11 connected to ML? Using an NL-ML converter?
If so, why did you set your BS5 to A.OPT 2?
Stefan
Cornelius
Posts 28
Cornelius replied on Tue, May 13 2014 6:12 PM
Correction, I have the BM5 on option 0.
Cornelius
Posts 28
Cornelius replied on Tue, May 13 2014 6:13 PM
The BV11 is indeed connected with an NL-ML convertor.
Cornelius
Posts 28
Cornelius replied on Tue, May 13 2014 6:18 PM
I found out why the tv didn't play radio in option 6, that was the speaker configuration which was wrongly set up. So now I can play with link x something over the TV and without link something over the speakers, but not at the same time, unless I connect the amp by means of PowerLink to the TV, but then I lose the function of the IR-eye.
Page 1 of 1 (11 items) | RSS
