I searched the archive and found the same question asked there but there was no answer. Is it possible?
I think TURN on an old BL1000 should do it but "SHIFT SOUND" whuch beocentral says this TURN on the later BL1000 does not work.
I added TURN to my Beo4 too but this does not work either...
Found it
GOTO SHIFT SOUND switches between AM/FM and then use GOTO up/down diamond to search.
