MMC4000 re-built then drama fitting it.
This post has 0 Replies | 0 Followers
jeules0
Posts 20
jeules0 Posted: Thu, May 22 2014 7:55 PM
Very pleased with the new cantilever and Shibata retip on my MMC4000 by Axel Shuerholz in Germany.
Posted it off from the UK and it was back in just over 2 weeks: excellent service!
The nightmare began when I snapped the plastic locating stub on the end of the tonearm on my Beogram 4000 trying to remove the MMC 20EN that I'd been using.
After a few choice words, I thought never mind I've got a spare on the parts-only deck I bought recently. I removed it from the donor deck easily enough after undoing a screw, sliding it off and unsoldering the wires on the connector board
I then removed the damaged one, only to find that this one had a completely different connector: it simply slid off with no wires visible, just brass strips on a slide-fit connector board.
To cut a long story short, I managed to make one good arm by wrecking the broken arm to extract the internal slide connection, and then soldering the wires from the good arm to it. I then made the connection and re-fitted the arm
MMC 4000 was then carefully fitted, VTF adjusted and now sounds great. Phew!
Page 1 of 1 (1 items) | RSS
