Switched on the TV tonight and the picture is terrible, really dark, on all sources and menus. Since I have not changed any settings, I fear the worst, that the panel has gone
Any thoughts would be most welcome
the TV is only a couple of weeks old!
thanks
Sorry to have bothered you. All is well. A techie friend of mine suggested turning it off at the mains for a couple of minutes, and that did the trick! Simples!
It mostly does - thankfully.
thorne: All is well
Glad to hear that worked for you.
