I have a problem with my BeoSound 5 Encore. My music is on a external hard drive connected with usb. Almost everything is working, but there are about 4 albums that aren't visible to the bs5e. For some reason I can't see them with the bs5e.
If I connect the hard drive to my computer I am able to see and play the albums. I also copied the "not working" albums from the hard drive to a memory stick and connected the stick to the A.MEM port and then the albums could be seen and played with the bse5.
The bs5e rescan -function isn't working when using external hard drive. Does bs5e write some hidden file to the hard drive that I could delete and after that perhaps bs5e would then find the albums?
Any other suggestions?
Thank you.
Tuomas
Hi again,
I solved (accidently) my problem by connecting a memory stick to the usb drive that usually has the hard drive in it. When connecting the hard drive again, encore this time found all albums. ??. No changes were done to the hard drive.
Still one problem remaining: some album covers are not seen, allthough they are correctly tagged with mp3tag -program.
