DVD1 KeyMaster Operating Instructions
jackson_db
Posts 11
Silver Member
jackson_db Posted: Mon, Jun 9 2014 10:41 AM
I picked up  DVD1 MKI with a KeyMaster circuit board and installation instructions taped to the inside of the cabinet.  I had the KeyMaster installed and this should make the unit region free.
It is working as using the boot-up while pressing << & >> I have been able to change the region over 20, clearly it prevents the region change counter from increasing.
I think there maybe ways of using the BEO4 or setting it so I dont have to keep changing between region 1 and 2.
If anyone has the operating instructions for the KeyMaster on the DVD1, please advise.
Many thanks, Darren
Fritz
Posts 272
Fritz replied on Mon, Jun 9 2014 11:43 AM
Hi
Go to the Access Control MENU in DVD 1. Change the Code to 0000, If you will change the Codes manually use the ones below. Auto: 0000, Region 1: 0001, Region 2: 0002, Region 3: 0003, Region 4: 0004, Region 5: 0005,Region 6: 0006, Normally Auto will work on all Dvd's Regions
Brgds/Fritz
jackson_db
Posts 11
Silver Member
Fritz,
Many thanks.  I set the player back to region 2, entered the 0000 access code and I have a region free player, with no more resets required.
Once again  - thank you.
Page 1 of 1 (3 items) | RSS
