Do I need a center speaker with a pair of beolab 5 ?
This post has 6 Replies | 2 Followers
olvisab
Posts 1,391
olvisab Posted: Fri, Jun 13 2014 10:34 PM
If I upgrade to a pair of beolab 5 do I need absolutely a center speaker and a subwoofer ?
The setup will be 2 bl5 and 2 bl1 as rear.
Thanks for your advices
4 beolab 5,  beolab 9, beolab 10, beolab 5000, beolab 8000 mk2, beolab 6002, beolab 3500, beovision 7 55 mk2,  2 beovision 11 46 mk4, beotime, beosound ouverture, beosound essence, beoplay A8, beomaster 900 RG de luxe and the collection continues...
Millemissen
Flensborg, Denmark
Posts 14,680
You surely don't need a sub!
For video you will need the center - unless you want to sit in the 'sweetspot' all the time....
...and your family in a line behind you Crying
For video with 5.1 sound you will miss the center channel, if you don't have the center speaker.
For audio (stereo sources) of course you won't need it.
olvisab
Posts 1,391
olvisab replied on Fri, Jun 13 2014 11:17 PM
ThSmileNks MM
Some say there is a kind of phantom speaker created by the beolab 5.
Maybe it is wide enough and more than a sweetspot.
I just have read this old thread :
http://archivedarchivedforum2.beoworld.org/forums/t/9005.aspx
Interesting.
Millemissen
Flensborg, Denmark
Posts 14,680
I'd suggest trying it out - to see if it works for you (and your family).
It would not be my advice.
N.B. I am aware of that thread - but I disagree.
Barry Santini
New York
Posts 543
It's not just the BL5s that can create a satisfying phantom channel. Speaker response, setup and room interaction all contribute too. But, for surround video delivered the way the mixing engineer intended, you should use a complimentary center speaker to your fronts.
mjmedlo
Posts 922
mjmedlo replied on Sat, Jun 14 2014 5:57 PM
You need a center speaker with that setup.
If you're going to watch any movies you'll want it.
Go for a 7.4. You'll never look back and regret that.
olvisab
Posts 1,391
olvisab replied on Sat, Jun 14 2014 7:29 PM
Thanks all for your replys.
I have to test the bl5 in place in order to see if the center is missing.
Unfortunately I tried the bl7.4 and the bl7.2 and I prefered the second.
What´s annoy me is how it will look in a rather small front space (2m60 of width).
The room is bigger than 70 square meters but the place where the tv is hanged is not wider than 2m60.
Page 1 of 1 (7 items) | RSS
