ML Gateway
This post has 1 Reply | 2 Followers
Seanie_230
UK
Posts 2,278
Seanie_230 Posted: Wed, May 2 2012 1:33 PM
Hello All
Which different home automation systems can the ML gateway communicate withi know it can communicate with control 4 and maybe x10 but what about some of the other brands like homesear and mcontrol that are not so dealer installed
Cheers All
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
tompa
Posts 64
tompa replied on Mon, May 7 2012 8:46 PM
It support at the moment this system:
Crestron, AMX, Control 4 and other fully programmable systems.
LK/IHC, Schneider/LexControl and ELKO (Intelligent House Control, Visual models with SW patch only)
Lutron Grafik Eye (GRX)
Lutron Grafix QS (QSE)
Lutron Radio RA
Lutron Radio RA2
Lutron Home Works Interactive
Conson Concept XP (converter from RS 485 to RS 232 is needed)
KNX compatible systems
Either TCP/IP or RS232 PEI-mode 10
 (FT 1.2 SW protocol). NOT PEI-mode 16 (HW handshake)
Clipsal
Dynalite
Vantage
BTicino My Home
Systems with simple RS232 or IP command and status strings
 and more because you can use command string for HA system that are not supported for now, just a little more work to get it work
Page 1 of 1 (2 items) | RSS
