BeoMedia/BeoMaster and config tool V6
This post has 0 Replies | 3 Followers
hfat
Vienna, Austria
Posts 663
hfat Posted: Mon, May 28 2012 7:29 AM
Hello,
I discovered that the version 6 of the tool duplicates N.Music and N.Radio sources when including BeoMedia1 or BeoMaster5 in a configuration. Investigating the issue i found the problem in an erroneous source type definition for n.music and n.radio. It can be corrected in two ways: First modifying the global key specification for n.music and n.radio. Second by corecting the product definition xml.
I'v put togehter i zip file with corrected procduct definitions for BeoMedia1 and BeoMaster5. The product names are suffixed with "602".
hfat
Page 1 of 1 (1 items) | RSS
