Beovox C75 - should lower woofer be dominant?
This post has 4 Replies | 2 Followers
twig
Posts 3
twig Posted: Tue, Apr 12 2016 6:54 AM
I have a question regarding my Beovox c75, that I bought last year. When I listen to the woofers, the lower one is dominant / plays louder than the upper one on both speakers. Is this correct or is anything wrong with my speakers? The lower woofers have rubber surroundings, while the upper ones have foam surroundings (I think they are all original). It should also be mentioned that the foam surroundings are old and just a little "sticky", and that the speakers are used in combination with Beovox Cona. Hope someone have knowledge about this as I love my speakers and want to fix them if there is anything wrong with them Smile
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Tue, Apr 12 2016 1:17 PM
Welcome to Beoworld !
Only one driver in each cabinet is a woofer.
The others are midrange and tweeter.
twig
Posts 3
twig replied on Tue, Apr 12 2016 7:09 PM
Thank you Dillen!
Then I assume that the upper driver is the woofer, and that the lowest frequencies are handled by the Beovox Cona? Smile
Dillen
Posts 13,191
Dillen replied on Tue, Apr 12 2016 10:09 PM
Yes, the upper driver is the woofer.
twig
Posts 3
twig replied on Wed, Apr 13 2016 7:40 PM
Ok, thank you =)
Page 1 of 1 (5 items) | RSS
