V1 flashing Red light.
This post has 10 Replies | 0 Followers
Simonbeo
Posts 1,451
Simonbeo Posted: Wed, Jul 2 2014 9:15 PM
We've had a power socket problem (caused by me trying to install a Phillips Hue hub) and on plugging the V1 back on the light is flashing red. The cable tv box and router are not connected . Is it to do with the need to reconfigure or could it be the TV damaged by a power surge when the Hue transformer exploded !
Beo Century ,Beoplay V1, Beocenter 6, Ex-Beolit 12, Beotime , A8. Beolit 15 , Form 2i , Beolab 2000, Beoplay A3.Beosound 1
Millemissen
Flensborg, Denmark
Posts 14,680
Could be because the pincode is activated...
Or because of an on-going update.
The tv does not turn on???
vikinger
Vestri Kirkjubyr, UK
Posts 5,422
vikinger replied on Wed, Jul 2 2014 10:08 PM
Millemissen:
Manual says slow red means use PIN.
Fast red could be software update underway, or a WAIT warning after too many wrong PIN entries.
Graham
Simonbeo
Posts 1,451
Simonbeo replied on Wed, Jul 2 2014 10:18 PM
We've never activated the pin code on the V1 but used it on our MXs . The Beoplay logo does not come up . Does that come after pin entry ?
Im leaving it for today . A it stressed!
The B&O dealer used a really cheap extension cord for the install but there was a fuse on the plug and the double power socket no longer works on that side . I'm rambling .....
Millemissen
Flensborg, Denmark
Posts 14,680
My V1 had the PIN activated per default.
Why not just contact your dealer.
Simonbeo
Posts 1,451
I called the dealer today and he will be sending a guy round on Monday . He researched it and suggested the red light may be for a PCB gone. An electrician is coming Tomorrow . In the mean time the distraught children are using the Beocenter 6 .
Simonbeo
Posts 1,451
Update; the Tv is fine , and the equipment in the B&O installation , but the electrician said that the Phillips Hue control hub adapter should not render the wall socket nonfunctional .
Michael
Sweden
Posts 2,578
Michael replied on Fri, Jul 4 2014 9:27 PM
Simonbeo:
Beo Century ,Beoplay V1, Beocenter 6, Beolit 12, Beotime , A8 , MX 5500 .
What was wrong?
Simonbeo
Posts 1,451
  1. It appears that the Phillips Hue adapter ,for its control hub, failed and caused a short to the wall socket . Luckily it did not go the other way to the bluray , wii and digibox and the V1.
Millemissen
Flensborg, Denmark
Posts 14,680
S**t happens.
Simonbeo
Posts 1,451
Millemissen:
S**t happens.
And luckily  all was well once the wall socket was replaced and it asked for the pin code . Phew . Now what can I buy with the money I don't have spend on a new tv?
Page 1 of 1 (11 items) | RSS
