When I switch on-off my BS9000 or i send a commando from remote control The beolab3 sparks. Simeone fan help me? i nave bene forced to CUT and reconnect a power link cable to one of the speaker could be this the issue?
Mlucarelli: When I switch on-off my BS9000 or i send a commando from remote control The beolab3 sparks. Simeone fan help me? i nave bene forced to CUT and reconnect a power link cable to one of the speaker could be this the issue?
You could try running a single power link cable to one speaker and eliminating the cable that has the splice in it to see if this is the cause of your problem.
I had a BS9000 that would make a "POP" sound in the speakers every time I turned it on and off, or switched inputs. The B&O shop ended up having to service that one after I returned it to the seller.
