LC1 programming with BL1000 MK3+
MJBeo
Netherlands
Posts 270
MJBeo Posted: Mon, May 26 2014 7:18 AM
I bought a pre-owned LC1 light controller, and I am trying to reprogram it using a beolink 1000 with light button. The manual on beoworld only shows tje mk1 and mk2 programming.
The LC1 works, and I can switch yo different lighting scenes.
However, I would like to know three things (for now ;):
1. How can I reset the current LC1 lighting scenes?
2. I am only able to control the lights using link-light-play/stop (also with the beo4: list (link)-light-go/stop). Is the LC1 set to be connected in a link room only? Can I also reset that?
3. The arrows up and down to dim the light do not work as explained in the manual. Should I use the volume buttons? Or the next track/previous track buttons?
4. Because I do not get any confirmation if I enter a programming sequence I am not sure if I am doing the right thing: I need to touch and hold the glass surface while entering the programming sequence, but should the light be switched off before I start (so when I touch and hold the surface the lights will be switched on), or is this not important?
Thanks in advance! In return for your help I will rewrite the LC1 manual for BL1000 MK3+ and Beo4, and upload it (is that possible?).
Beosound 5 Encore + Beosystem 5500 + S45.2; BV7-40 MKV + BL7.1 + BL14.4+ AppleTV4; various link rooms with MCL2 A or MCL2 A/V + RL60.2 / CX100 / CX50 & Cona  / IWS2000; BG4000; Beosystem 1200 + BV1600.
MJBeo
Netherlands
Posts 270
MJBeo replied on Tue, May 27 2014 5:51 PM
Guys?
MJBeo
Netherlands
Posts 270
MJBeo replied on Wed, Jul 9 2014 9:46 AM
Figured it out: it was set to work with MK1 beolink1000, and I confused the programming:
LINK-SHIFT-LINK-GOTO-0-STORE can be achieved with LINK-LIGHT-GOTO-0-STORE on a MK3 beolink1000.
Operation was perfect after this.
Page 1 of 1 (3 items) | RSS
