Anyone using a Receiver 1?
A friend of mine told that his BL3's don't go into standby, when used with the Receiver.
Really - noone?
Hi MM, I'm actually supposed to have a set of Receivers 1s connected to a pair of BL3 used as surrounds to my BV11 (see my set up on the Flash your B&O thread), but am not having a good experience. I'm awaiting on my dealer to receive and install a 3rd set, since the first two sets were faulty.
The first set that got installed worked for a couple of days and then went dead (there's a known problem with a PCB on the earlier versions). The second set that was brought to my house couldn't even power up the speakers. Hopefully this new set coming next week will solve the problem.
From what I could notice, based on my limited experience with the 1st set, the BL3s didn't go on standby when the TV was off under the "quick start" mode. However, when the TV was off under "power savings" mode then BL3s went on standby. Hope this helps and I'll post my experience when I receive a working set...
Millemissen:Really - noone? MM There is a tv - and there is a BV.
BeoNut since '75
Not me being impatient!
My friend is impatient.
And for friends you are supposed to do all that is needed....
Thanks - talfaia.
