Hi everyone,
I just joined this forum and I'm learning an awful lot searching through past posts. I haven't found the answer I'm looking for so here it goes:
I just purchased a set of second-hand Beolab 8000 speakers at a great price. I intend to make them part of a 5.1 Surround setup for my home studio and wanted some advice on other similar setups.
I work in post production (colour grading) and as a result the audio will be delivered to the audio processor via an SDI feed, which will carry both the video and audio. The audio will be de-embedded and then connected to the processor using either XLRs or a 25pin cable.
I have a few questions:
1) What speakers have people paired up with the Beolab 8000 speakers to funtion as C, Lfe, Ls and Lr, assuming the 8000s are configured as L/R?
2) What's a good audio processor (older B&O model or other manufacturer) that works well in this configuration?
3) Are special cables required with non-B&O systems to trigger these speakers?
Any help or pointers (especially previous links) would be appreciated.
thank you!
milton
Check the link in my signature...
Ralf
