Beomaster 5500 won't turn on but does go to standby
duncanski
Posts 2
duncanski Posted: Fri, Jul 11 2014 8:22 PM
hi all,
feel silly asking but I have read the blogs but cant find what this could be.
I have a beomaster 5500, has not marks/bumps etc but I dont have a remote
As it turns on you can hear the relays clicking and the red text showing on the screen (appears to be a power cycle) then it goes to stand by. is this normal ? ?
hope you can help
Duncan UK
DMacri
United States
Posts 881
DMacri replied on Sat, Jul 12 2014 11:45 PM
Others will be able to confirm, but it sounds like it is going into protection mode. The bias pots may need to be adjusted, but often the recommendation is to replace the old caps and the pots before adjusting the current level.
Dom
2x BeoSystem 3, BeoSystem 5000, BeoSystem 6500, 2x BeoMaster 7000, 2 pair of BeoLab Penta mk2, AV 7000, Beolab 4000, BeoSound 4000, Playmaker, BeoLab 2500, S-45, S-45.2, RL-140, CX-50, C-75, 3x CX-100, 3x MCL2 link rooms, 3x Beolab 2000, M3, P2, Earset, A8 earphones, A3, 2x 4001 relay, H3, H3 ANC, H6, 2014 Audi S5 with B&O sound, and ambio
Playdrv4me
USA
Posts 477
DMacri:
It sounds like it's doing that to me, too.
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Sun, Jul 13 2014 6:56 AM
Check also the solder joints at the output stage driver transistors and the amplifier power relay.
duncanski
Posts 2
duncanski replied on Sun, Jul 13 2014 2:21 PM
thank you very much guys.
I have found a local service company that can fix it, so going down that route, as it all sounds very complex!
but your help is really appreciated , as its easy for punters like me to get lost in all the technical wording
Thanks a million
duncan
Page 1 of 1 (5 items) | RSS
