Hi everyone,
I found a NOS ambiophonic adapter for using with my Beomaster 8000!
Trouble is, no L-R indications anywhere on the box, or on the DIN plugs/sockets.
The manual doesn't allude to any L-R settings either.
How do you do?
Jacques
The secret is, that it doesn't matter.The two rear (ambio-) speakers are working in parallel (mono), fedonly the difference signal from the left/right speaker inputs.So it will work and produce the same result regardless.
Of course! This makes sense!
Thanks Martin
I quote the manual:
"The sockets ans plugs of the adaptor are not marked L and R for left and right because this is immaterial. However, the two front speakers are to be connected as for stereo."
Perhaps I should have read...
