BeoSound Stage and LG C1 Volume Control
This post has 5 Replies | 0 Followers
Buckturgidson
Posts 2
Buckturgidson Posted: Fri, Jun 25 2021 7:40 PM
New member here.  I've been struggling for a couple of days with issues on setting up my BeoSound Stage with a new 2021 model LG C1 series TV.
I've worked my way through the setup with some great help from the B&O help desk folks.  I'm an old guy that barely knows how Apple Airplay and Google Home work on a wireless network.
The Beosound Stage is now is now up and running through the eARC HDMI connection on the TV with one problem.  I can't control the volume with the LG TV remote control.  I've tried resets, unplugging/plugging back in, etc.  I've been through ever item in the LG settings and can't find a problem.  I contacted the LG help-desk, and the technician had never heard of Bang & Olufsen and said he would get back to me in a half hour.  That didn't happen.  I finally hit my frustration point and ordered a Beoremote One today, but I hate being dumb and not being able to figure out my problem.
Thanks to anyone that has a suggestion.
Mikipidia
Posts 2,169
Mikipidia replied on Fri, Jun 25 2021 7:58 PM
Did you connect a ethernet cable between the tv and the stage?
Mikipedi4 on Twitch: https://www.twitch.tv/mikipedi4
Mikipedia on Intagram: https://www.instagram.com/mikipedi4/
Old: Beosound 9000 mk3, Beolab 3's, Beovision Eclipse, Beolab 1's, Beolab 2, Beovision 10-46, Overture 2300, beolab 8000's, Beolab 4000's, Beovision avant 32" etc. etc.
Hiort
Sweden
Posts 2,895
Hiort replied on Sat, Jun 26 2021 8:55 AM
Welkome to the forum Smile
Instructions on how to connect:
https://support.bang-olufsen.com/hc/en-us/articles/360039890071-Installation-Guide-Beosound-Stage-and-LG-C9-in-integrated-setup
Mikipedias suggestion regarding the LAN cable is my bet.
Buckturgidson
Posts 2
I did not have the ethernet cable connection.  I did this, and also downloaded the B&O app from the LG store on to the TV.  I'm not sure which one was the solution, but I can now control the volume from the TV remote.  I will say that I didn't have to do this on my 2019 LG C9 series TV.  But with a new 2021 LG C1 series TV, this needed to be done.  Interesting.
Thank you for your help.
vlohjr1
Posts 553
vlohjr1 replied on Mon, Jun 28 2021 8:05 PM
It’s both.
i have the c9 panel and I need to download the software from LG store to control the the stage thanks
Millemissen
Flensborg, Denmark
Posts 14,680
Buckturgidson:
In your initial post you wrote: I can't control the volume with the LG TV remote control.’
Was that you intention?
If yes - I am curious - why don’t you want to use the Beoremote One?
Page 1 of 1 (6 items) | RSS
