Is there a secret to getting to spring mechanism back in place i havve it al back together bu the strength is not there to hold it up .I dowmloaded the print but no help, Is there a trick and which wasy does the sprigs ends face on the dust cover. Towards the grooves are away from it. Thanks in advance plus i will need a new belt if they are out there.
