Test Record with same left and right channel output?
RAJOD
Posts 159
Silver Member
RAJOD Posted: Sun, Jul 20 2014 11:17 AM
Is there such thing as a test record to see if the phono/cart is outputting the same to each channel?
Sometimes my left speaker will be down in volume vs the right.    I'll change outputs and then the right channel is down.
Thought it might be my amp crapping out but maybe its my cartridge.   I have a mmc2 and mmc3 and both seem to have this intermittent issue.    So it might be even something inside my 8002 that is not cartridge related.
It would be nice to have a record that was mono so I could test easier.
MediaBobNY
Greenwich Village, NYC
Posts 1,106
This one, for example.  The first track does it twice with 2 different sounds being sent repeatedly to the L then R channel.  Makes it very easy to compare output levels.
Leslie
the Netherlands City
Posts 5,423
Silver Member
Leslie replied on Sun, Jul 20 2014 7:46 PM
Or this one...
Brengen & Ophalen
Page 1 of 1 (3 items) | RSS
