tuttivini
Posts 186
tuttivini Posted: Tue, Aug 5 2014 9:05 PM
beojeff
USA
Posts 2,012
beojeff replied on Tue, Aug 5 2014 11:57 PM
No. The cona is inadequate for even the BeoLab 6000s. I tried it years ago and couldn't even tell that the cona was present. It was never really intended for the LFE but rather to "fill out" the bass of the BeoVox CX50 and CX100 speakers.
Ben_S
UK
Posts 631
Ben_S replied on Wed, Aug 6 2014 11:05 AM
The Cona isn't designed for this kind of set up really.
It is absolutely noticeable if you have some CX100s like I have, it makes a subtle but noticeable difference to the sound, which actually makes it a really pleasant sounding system.
For your purposes however, it just won't be noticeable.
DMacri
United States
Posts 881
DMacri replied on Wed, Aug 6 2014 12:13 PM
You can hook it up as you suggest, but a passive subwoofer like this has some positives and negatives. You would usually hook up passive satellites like CX series speakers. The Cona would filter the low frequencies from reaching the CXs - allowing them to play louder with less distortion. Then the Cons would play the low frequencies from both channels. In your configuration, you would not be able to take advantage of the internal filter and the Cona and the BLs would play some of the same frequencies. This could cause some odd frequency and time domain issues unless you are careful with your placement.
Dom
2x BeoSystem 3, BeoSystem 5000, BeoSystem 6500, 2x BeoMaster 7000, 2 pair of BeoLab Penta mk2, AV 7000, Beolab 4000, BeoSound 4000, Playmaker, BeoLab 2500, S-45, S-45.2, RL-140, CX-50, C-75, 3x CX-100, 3x MCL2 link rooms, 3x Beolab 2000, M3, P2, Earset, A8 earphones, A3, 2x 4001 relay, H3, H3 ANC, H6, 2014 Audi S5 with B&O sound, and ambio
Page 1 of 1 (4 items) | RSS
