BeoVision LX 2800 en DVD speler aansluiten op scart werkt niet :(
This post has 1 Reply | 0 Followers
MihoWatashino
Posts 15
MihoWatashino Posted: Sun, Jun 24 2012 3:43 PM
Hi Guys,
I have a minor problem with connecting a DVD player to the BeoVision.
Currently I am using a BeoLink 1000 terminal to control the LX 2800
I did found a code which could work but it did not, I got in AUX 2. menu though...
the code went like pressing: shift + v.tape + tv + 2
and then it should work
Hopelijk weet iemand wat het probleem kan zijn om wel beeld van de DVD speler te krijgen :)
Bedankt alvast,
Miho
Beobuddy
Utrecht, The Netherlands
Posts 3,972
Hoop dat dit werkt..
Page 1 of 1 (2 items) | RSS
DigiCert Secured Site Seal
