7 Pin din Cable solution
Dave
Posts 40
Dave Posted: Mon, Aug 4 2014 12:22 PM
Hi I thought this may be of interest. I purchased two 7 pin Din to 7 pin Din Acorn BBC Micro Model Cassette Tape Leads at £5.99 each, just as an experiment to se if they would work as audio and datalink cables between by Beogram 6002, Beocord 8000 and Beomaster 6000. They do, I can control the tape deck and record deck using the remote now through the Beomaster. I assume they must be correctly wired as everything works as it should and there's no hum from the turntable. They may not be of the best quality, but for the price they will do me until I can afford to have two professionally made audiophile type cables made up.
Steve at Sounds Heavenly
The cable workshop, Leics, UK
Posts 2,165
Hi Dave,
Yes, they should be correctly wired, the issue is likely to be the lack of shielding on the audio and Datalink wires, so you may see reduced stereo separation between the channels, as well as hearing "clicking" on the audio caused by cross-talk from the Datalink wires.  That is a low price, but please bear in mind that for a few pounds extra, you can get the correct fully shielded cables for good sound quality! Wink
Kind regards, Steve.
PS. I may still have a BBC model B Micro computer in the loft somewhere.......
Steve.
www.soundsheavenly.com
Dave
Posts 40
Dave replied on Mon, Aug 4 2014 4:21 PM
Hi Steve
Will be in touch for better cables as soon as i have had my Beogram 6002 repaired. I got a 5 pin din female to male extender cable from you recently, by the way and it works great.
Posts 2,165
Thanks Dave! Big Smile
Steve.
chartz
Burgundy, France
Posts 4,171
chartz replied on Mon, Aug 4 2014 7:03 PM
Hi!
For short leads (up to 1 metre), I use shielded network cable with Neutrik plugs.
Jacques
Page 1 of 1 (5 items) | RSS
