Dear members,
I am trying to connect a VX7000 to an MX8000 with dolby digital module. No external speakers connected. While I do get a picture and the VX7000 seems to be working fine, there is absolutely no sound. Any idea what this lack of sound can be due to?
Thanks!
Greetings,
Kai
Hi there,
can't say for sure. Have tried two different Scart cables to no avail. Maybe they were both not fully wired? Are you sure that you need a fully wired one? How can you tell whether it is that or not?
There is cinch audio out on the VX7000. Can this be used to get sound to the MX8000? Sorry to be so lost here. I have had a similar issue with my DVD2 when connected to the old Avant. Scart didn't transport any sound and separate connection via jack had to be made. That did the trick then. But since the audio out of the VX7000 is analogue and the audio in on the MX8000 is digital, I would probably need a converter, wouldn't I?
I am pretty sure that it is due to the DD module. A converter will be needed.
Thanks! Kai
When using VX7000 and a MX 8000, a fully wired scart cable is needed, and connection to V.tape scart socket.if the MX 8000 has been fitted with Dolby Digital module 32 in the V.tape connection menu SPDIF socket A or B to be set to Off. No need for a converter.
makes a lot of sense. That is exactly what I did except for the SPDIF setting. I can't seem to find it. Whre is it supposed to be? I have looked everywhere and no entry where to disable SPDIF.
