No Netflix app on a BV- why?
This post has 47 Replies | 4 Followers
Marcello
Posts 213
Marcello replied on Wed, May 21 2014 1:21 PM
Fresh news: Netflix coming to France, Germany, Belgium, Austria, Switzerland and Luxembourg.
http://finance.yahoo.com/news/netflix-launch-six-european-countries-040425978.html
symmes
Posts 247
symmes replied on Wed, May 21 2014 4:11 PM
Unless it's built in for 4K capability, partnering with just Netflix is a waste of development resources for B&O (in my often humbled opinion).
Guy
Warwickshire
Posts 2,590
Guy replied on Wed, Sep 3 2014 3:25 PM
Any further developments on a Netflix for BV?  I am considering a BV11 and was trying to work out how many additional boxes I need.
Incidentally it is Netflix that has finally forced me to look for a new TV, as the current one (BV6) doesn't have hdcp!  I am using a WD TV Live and have had to switch back to composite output because my DVI input has no hdcp.
Interestingly, the latest WD TV's do not have the Netflix app installed, even when bought in UK, so perhaps there are some recent licensing issues.
rxcohen
New York
Posts 201
rxcohen replied on Wed, Sep 3 2014 5:52 PM
No news that I know of, but just stick an appleTV behind the BV11 and you have netflix, apple movie and music streaming, and a host of other things. It works very well and there is even a compartment inside the BV11 for it. It is only $100 (or equivalent in Europe), takes up only 1 hdmi and rather invisible once installed. I programmed one of the buttons on the Beo4 for appleTv, so I can just go directly to it when I turn the TV on. Frankly I don't see much value in building netflix into the TV.
BV11-55, BS9000, BL1, BL19, Transmitter 1, Beo4, Beocom 6000, BeoTalk1 200, Sennheiser HD600, McIntosh MHA100
mjmedlo
Posts 922
mjmedlo replied on Wed, Sep 3 2014 6:00 PM
rxcohen:
I suggest Roku over Apple TV.
Guy
Warwickshire
Posts 2,590
Guy replied on Wed, Sep 3 2014 6:07 PM
Thanks for the reply - makes perfect sense!  I will probably stick with a WD TV as I have yet to find a file type that it doesn't support, plus BBC iPlayer works fine.  It's slightly bigger than Apple TV and also needs a separate PSU so I wouldn't stick in the back of the TV.
I will probably move the old TV and WD TV to the bedroom, hence I was just wondering if I need a extra WD TV.  Perhaps I will get an OPPO instead, after all my DVD1 will need replacing!
krito908
Posts 2
krito908 replied on Thu, Jun 25 2020 6:09 AM
Here is the new netflix mod. This might help you.
kuyttendaele
Posts 707
krito908:
No it won't as you are not able to install it in your TV
Page 2 of 2 (48 items) < Previous 1 2 | RSS
