"Believe nothing you read and only half of what you see, let your ears tell you the truth."
Thanks for mentioning that, Chris
Note: You don't need to have a Twonky server running to use Twonky Beam.
The app recognizes other DLNA servers too.
Give it a try - it's free!
Anothr good thing I have noticed since the update is, for instance, when you are naming a speaker group, you get a proper qwerty keyboard on the screen, rather than having to scroll through all the letters using the central nub
excellent
