H6 Replacement Audio Cable?
This post has 48 Replies | 2 Followers
Millemissen
Flensborg, Denmark
Posts 14,680
Correct - that is the PN of my cable.
However, I don't see any type no on the box.
No - i did not hear any differences with that cable.
Otherweise (at least - if 'difference' would mean 'sounding worse'') I would have returned it to my dealer
immediately....
....and I would have warned about it here.
js
Posts 382
js replied on Wed, Feb 18 2015 2:39 PM
Thanks Roger and MM  Yes - thumbs up
elephant
AU
Posts 8,219
elephant replied on Wed, Feb 18 2015 3:12 PM
js:
Thanks Roger and MM
Confirming the part number in triplicate.
And I was referring to the loss of the data signal, not the audio signal which is fine.
By data I mean the controls + -
It is definitely meant for the H6 as it has a printed guide on the side of the box Laughing
BeoNut since '75
leosgonewild
Helsinki, Finland
Posts 2,373
Where did you get this information? I am using them with a regular 3 conductor plug without problems.
leosgonewild
Helsinki, Finland
Posts 2,373
Sorry, my wuoting did not work for some reason.
Someone stated that the 4-conductor cable do not work on a headphone amp. Where is this information from?
elephant
AU
Posts 8,219
elephant replied on Wed, Feb 18 2015 8:49 PM
that works.
That's the standard in box cable.
The "replacement" cable is NOT same 4-conductor
Nor does it have the controls built into the cable (obviously)
BeoNut since '75
Millemissen
Flensborg, Denmark
Posts 14,680
A 'replacement cable' is meant to replace another - in this case for users, who don't need the 4-pin/remote version.
If you need a '4-pin cable', that is longer than the default, it would be a 'long iDevice-compatible cable' - and not a 'long audio cable'.
I don't know, if that exists.
MCryingM
leosgonewild
Helsinki, Finland
Posts 2,373
As an iDevice is a portable device that you carry with you, that is a non-existing problem in my opinion.
Unless you want to keep your iDevice in your sock while you are running Hmm
al1947
Posts 1
al1947 replied on Sat, May 2 2015 6:40 PM
U.S. site (and Amazon) has two lengths of cables without remote and replacement iDevice and Android cables with remote
http://www.beoplay.com/accessories/h6
Sadly, Sounds Heavenly does not believe an upgraded cable is possible because the slim plug surround leaves no room for more robust wire...
Page 2 of 2 (49 items) < Previous 1 2 | RSS
