Chris Townsend:By the time you've gone through the entire range, you may as well get some Beolab 5's. Been there, done that.
That takes all the fun out of it though if you like playing with lots of different gear! I still think he's going to have a hard time finding a single speaker that will work, speakers with large subs seems to be the the best approach IMO if he wants to avoid large pro speakers. You can add subs until you get enough air moving ability to get the bass he wants without stress. And subs can be disguised as tables, etc. and made to disappear depending on the room design.
Jeff
