My very own Beocord 2400
This post has 217 Replies | 2 Followers
chartz
Burgundy, France
Posts 4,171
chartz replied on Mon, Oct 27 2014 9:36 AM
By the way, one of the red-pink bulbs has lost its colour. Is there a special paint for bulbs?
NO LEDS - I am a permanent and founding member of the no-LEDs-in-vintage-equipment club.
Jacques
chartz
Burgundy, France
Posts 4,171
chartz replied on Mon, Oct 27 2014 10:51 AM
Back together! A first listen with headphones is positive. I get a bit of spurious noise on one channel, below music level. Crackling noise, but not in the treble or midrange areas, I'd say below 600 Hz.
The caps underneath the pot, like Søren? When volume is zeroed, no noise at all, which eliminates the amplifiers.Switching to mono (either channel) doesn't make any difference.
The transport is not silent, but friction noise is acceptable, and inferior to spool noise (the tape slightly rubbing on the flanges). I'll have to replace that self-destructing foam! The rotation of the motor gradually makes it disappear in thin air!
By the way, has anyone got an original B&O extra spool? Embarrassed
Jacques
Christian Christensen
Stockholm
Posts 512
Jasques, I am not really sure what you are asking of..is it a image from this direction  you need ?
My re-capped M75 are my precious diamonds.
Stockholm
Posts 512
An extra spool ?,
Not sure, I might, next week when a nother broken machine is arriving. I will get back to you regarding the spool
Christian
chartz
Burgundy, France
Posts 4,171
chartz replied on Mon, Oct 27 2014 12:04 PM
Christian Christensen:
Yes, thanks, and after that, where does it exit?
Jacques
Stockholm
Posts 512
Stockholm
Posts 512
Stockholm
Posts 512
Stockholm
Posts 512
I have the service manual if you are looking for some particualr schemtaics.
Its over 70 pages including huge foldups, so I don thave time yet to scan all of it, but can scan needed parts for you later tonight.
chartz
Burgundy, France
Posts 4,171
chartz replied on Mon, Oct 27 2014 12:23 PM
Err... The black wire from the auto-stop! It goes to the switch lever on the left hand side of the control panel.
I have the manual, it is on Beoworld, but thanks!
Jacques
Stockholm
Posts 512
That black cable goes under the pinchroller and end up sticking out  bellow the transport joystick with a mounted pin on the end to stick to the metal frontplate as an ground cable
Can take image later tonight...on my way out...
Søren Mexico
Mexico City
Posts 6,411
Søren Hammer:
@Søren: Do I spot the B&O reel that I gave you when you visited me? Whistle
Oh yes, Søren, that is the reel, and it has already been of good use, during tests. And thank you again
chartz
Burgundy, France
Posts 4,171
chartz replied on Mon, Oct 27 2014 4:42 PM
Checked voltage, almost spot-on at -24.2 V; it should be 25 V. After all these years!
I tried the amplifier, it sounds really good, as expected. A small Beolab 5000! And with a headphone output... Whistle
That's all for today, I have this canvas frame to do for my daughter now.
Jacques
Stockholm
Posts 512
Thank you Jascues, for the information about how the cap works with the motor, that I didnt know.
Working with reel to reel machines is though not new to me.
Here replacing pinch roller with brand new , as I inted to have the BC2400 on first spot being used until I die :).
Stockholm
Posts 512
Here image of the cable for you
chartz
Burgundy, France
Posts 4,171
chartz replied on Tue, Oct 28 2014 6:40 AM
Thank you!
Jacques
chartz
Burgundy, France
Posts 4,171
chartz replied on Tue, Nov 4 2014 7:25 PM
So Christian, have you made any progress?
Right now, there's nothing more I can do until I have ordered the new components. I have not listed them yet, but there's an awful lot of capacitors and small signal PNPs to replace. I will replace the transistors (rec. and replay boards) as advised by Frede.
The cosmetic restoration is finished, including the black cardboard strips. All screws look shiny new (I use a mix of hydrochloric acid and pure water) and the panels are cleaned.
One little flaw: I can see where the old plastic sheet was over the control panel and the paint actually looks better where it wasn't!
Jacques
chartz
Burgundy, France
Posts 4,171
chartz replied on Thu, Nov 6 2014 7:23 AM
I have now put the Beocord back together for testing purposes.
Unfortunately, the main idler wheel's noise, which was very discrete without the box, is amplified by the wooden case.
The noise level being unacceptable, I'll have to replace the wheel with a new - or refurbished - one. Until this is done, I will do nothing else.
Jacques
Stockholm
Posts 512
Jassque, can you show me a picture of what you mean by a spool
My Becord 2400 is finished for now., sounds great, really fantastic. it didnt need any BIAS adjustment.
After Christmas I will conitnuie to recap it completly.
Some people might this it is not necessary. but I intend to keep this for ever and use it alot, so why now reaplace old components. replacing compnents lower the risc for future circuit collapses.
Christian
chartz
Burgundy, France
Posts 4,171
chartz replied on Fri, Nov 7 2014 4:55 PM
A spool?
My Beocord's heads are well worn, kaput in fact, so the sound is not fantastic!
And the noise emanating from the idler wheel is honestly unbearable. I will have it refurbished.
I think I will have to find another one, with good heads. Oh well.
Jacques
Stockholm
Posts 512
spools, arnt they easy to find ?, you mentioned something about a spool earlier ?
I will keep this in mind about the bad heads,
Have you asked Martin ?
chartz
Burgundy, France
Posts 4,171
chartz replied on Fri, Nov 7 2014 9:03 PM
No, not yet. Martin, are you here? Embarrassed
Jacques
Stockholm
Posts 512
Martin, seems to be less here on Beoworld lately.
Life takes people in different phases.
Suggest you to send him an email from his site
http://beoparts.com/
I bet he will reply quick.
Stockholm
Posts 512
....hmmm. btw,
how have you determined that teh heads are bad ?
Can you see that they are physical worned out after cleaning ?
Does the playback sound bad ?
Have you demagnitized the heads ?
Azimuth ? do you have control of the circumstances ?
Is it quality difference between record and playback ?, are you using fresch new tapes, adjusted plaback and record levels ? Bias adjustment ?
Just curious :)
C
chartz
Burgundy, France
Posts 4,171
chartz replied on Sat, Nov 8 2014 9:04 AM
I use pre-recorded tapes which I know are good. I've got three other open reel machines, a Sony and two  Revoxes I have refurbished to as-new condition.
The heads are physically in bad shape, being deeply marked, and irregularly so. Perhaps the heads had been badly centered at some point or even in the factory. This happens, but is only visible after years of use. Anyway, the wear mark is about 4 mm wide, and reaches the bottom of the upper slots.
Adjusting anything with such heads is illusory and can only lead to disappointment. So far the scope has remained in its box!
Jacques
Stockholm
Posts 512
Does it sound bad ?
chartz
Burgundy, France
Posts 4,171
chartz replied on Sat, Nov 8 2014 11:27 AM
It does, yes.
Jacques
chartz
Burgundy, France
Posts 4,171
chartz replied on Sat, Nov 8 2014 3:45 PM
I've just tried recording. The tape is erased, but nothing is recorded onto it. The meters do work.
Jacques
Stockholm
Posts 512
Could be the recording switches
Stockholm
Posts 512
I am very curious about the heads, could you proviade a close up image ?
chartz
Burgundy, France
Posts 4,171
chartz replied on Sat, Nov 8 2014 4:02 PM
No, they work, contacts are fine.
Jacques
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Sat, Nov 8 2014 10:22 PM
Sorry, I couldn't help it. I just happened to come across this in one of the boxes. Geeked
For the older B&O models using the modular plug-in boards an extender cable was available to ease servicing:
Given a donor unit for the connectors, it shouldn't be too difficult to make one up yourself if needed.
chartz
Burgundy, France
Posts 4,171
chartz replied on Sun, Nov 9 2014 9:16 AM
Nice one Martin!
I found the culprit. The record head is open-circuit, on both channels. Sad How can that happen?
No wonder nothing was transferred to tape!
Jacques
Dillen
Posts 13,191
Dillen replied on Sun, Nov 9 2014 11:40 AM
For these decks, this is actually not particularly unusual. Crying
chartz
Burgundy, France
Posts 4,171
chartz replied on Sun, Nov 9 2014 2:46 PM
Here's the headblock. You can see both heads worn at the bottom. One channel does play fine, while the other sounds really bad (little treble) and you can see why!
Tilt was possibly misaligned at the factory.
Jacques
chartz
Burgundy, France
Posts 4,171
chartz replied on Sun, Nov 9 2014 5:48 PM
A crackling noise on the left channel, when using headphones - line out completely bypasses the volume pot - had me look for a problem on the amplifier module. A quick look at the diagram made me suspect a bad transistor and I was right. The BC154 was leaky, and replacement with a modern PNP equivalent (BC251B) completely cured the problem.
One little thing at a time I suppose! Stick out tongue
Jacques
Søren Mexico
Mexico City
Posts 6,411
As you know my BC 2000 has all germanium transistors, AC 107, AC 126 etc, etc, these or their newer equivalents are expensive, any way to change to silicon TRs
chartz
Burgundy, France
Posts 4,171
chartz replied on Sun, Nov 9 2014 7:36 PM
Søren Mexico:
As you know my BC 2000 has all germanium transistors, AC 107, AC 126 etc, etc, these or their newer equivalents are expensive, any way to change to silicon TRs?
I guess it is possible, but perhaps not at the snap of a finger. You should compare old diagrams to newer ones and see what B&O did when they switched over to silicon. Do you have defective ones?
Jacques
Søren Mexico
Mexico City
Posts 6,411
chartz:
Until now I didnt find any bad ones, but they will come sooner or later, the Ge cost between 3 and 7 USD a piece, where a couple of resistors and Si TR will be less than 1 USD. I will have to look into the BC 2400 circuits.
tournedos
Finland
Posts 7,357
Germanium transistors (and other semiconductors) have different threshold voltages compared to silicon semiconductors, so in general, you cannot just switch over without a lot of changes to the surrounding circuitry as well.
--mika
Page 2 of 6 (218 items) < Previous 1 2 3 4 5 Next > ... Last » | RSS
