Just got a hold on all the features and functions regarding this new update, and not only for Avant
Have a nice day and enjoy reading...
New features
UHD 60p (BeoVision Avant)
AAC format support for NetRadio
BeoRemote One MyButton increased storage timing
Symptom
BeoPlay V1
Writes NO SIGNAL intermittently (9961)
Video playback via NAS is lagging on HomeMedia with specific mov file (10489)
Pixelation in picture at DVB-C after SW update to 1.0.8.36550 (11648)
No sound from standby (11889)
Temporary picture distortion after channel change (12133)
BeoVision 11
No LAN/WAN after turn ON (10429)
Suddenly switched off when watching TV and incident not logged in Report or on USB (10487)
Pixelation in picture on DVB-C after SW update to 1.0.8.36550 (11648)
BtB: Cannot get TV to start on specific channel (11718)
High pitched noise (12146)
Stable sine tone and partly deadlocked TV after a night of Network Link playback (10781)
Timer recordings overlap - even when planned for different days (11452)
No teletext on SRF1 HD and RTS UN HD (11488)
Product suddenly switch off and report data missing for several days (11884)
BeoSystem 4
BeoVision Avant
No LAN/WAN after switching on (10429)
At standby the speaker bar came in from the sides but did not retract into the television (11390)
No N.RADIO, just shows 6 channels as "B&O Test" (11481)
TV does not enter standby in integrated setup (11885)
1 TB USB 2.0 HDD is not recognised as a suitable HDD, so you cannot set up HDD recording
(10621)
Missing N.RADIO station NRK P13 (11509)
Crash/slow when stepping in programs (11512)
No sound in the internal speakers (11513)
No TV tuner picture when exiting HbbTV video with red button (11600)
The TV re-boots/switches off without curtains every time a sound set-up is stored (11879)
Time-out for N.RADIO is too small causing Avant N.RADIO Connection Error message (11892)
Very short interruptions of Internet radio every few minutes on all channels. Sound drop-out on sw
1.0.8 (11894)
Intermittently does not switch on/show picture or sound from standby. After a mains reset it has
picture and sound (12243)
21. BVA-55 When selecting N.RADIO, the unit seems to have problems with buffering and, in most cases, it crashes/freezes (12301)
Cause
New functionality and error correction
Solution
Update to version 1.0.10.37040 Please remember to keep yourself updated with the Registered Quality Problems!
Compatibility
All BeoPlay V1, BeoVision 11, BeoSystem 4 and BeoVision Avant can be updated with the new version.
Thanks to BeoFantast
Greetings Peter Pan
Aussie Michael:Make sure your IR is slightly off centre. If it's right on top it lags
Beolab 50, Beolab 8000 x 2, Beolab 4000 x 2, BeoSound Core, BeoSound 9000, BeoSound Century, BeoLit 15, BeoPlay A1, BeoPlay P2, BeoPlay H9 3rd Gen, BeoPlay H6, EarSet 3i, BeoVision Eclipse Gen 2 55", BeoPlay V1-40, BeoCom 6000 and so much else :)
BeoFantast:Just got a hold on all the features and functions regarding this new update, and not only for Avant Have a nice day and enjoy reading... New features UHD 60p (BeoVision Avant) AAC format support for NetRadio BeoRemote One MyButton increased storage timing Symptom BeoPlay V1 Writes NO SIGNAL intermittently (9961) Video playback via NAS is lagging on HomeMedia with specific mov file (10489) Pixelation in picture at DVB-C after SW update to 1.0.8.36550 (11648) No sound from standby (11889) Temporary picture distortion after channel change (12133) BeoVision 11 Writes NO SIGNAL intermittently (9961) No LAN/WAN after turn ON (10429) Suddenly switched off when watching TV and incident not logged in Report or on USB (10487) Video playback via NAS is lagging on HomeMedia with specific mov file (10489) Pixelation in picture on DVB-C after SW update to 1.0.8.36550 (11648) BtB: Cannot get TV to start on specific channel (11718) No sound from standby (11889) Temporary picture distortion after channel change (12133) High pitched noise (12146) Stable sine tone and partly deadlocked TV after a night of Network Link playback (10781) Timer recordings overlap - even when planned for different days (11452) No teletext on SRF1 HD and RTS UN HD (11488) Product suddenly switch off and report data missing for several days (11884) BeoSystem 4 Writes NO SIGNAL intermittently (9961) Video playback via NAS is lagging on HomeMedia with specific mov file (10489) Pixelation in picture on DVB-C after SW update to 1.0.8.36550 (11648) BeoVision Avant No LAN/WAN after switching on (10429) Video playback via NAS is lagging on HomeMedia with specific mov file (10489) At standby the speaker bar came in from the sides but did not retract into the television (11390) No N.RADIO, just shows 6 channels as "B&O Test" (11481) Pixelation in picture on DVB-C after SW update to 1.0.8.36550 (11648) TV does not enter standby in integrated setup (11885) No sound from standby (11889) High pitched noise (12146) Stable sine tone and partly deadlocked TV after a night of Network Link playback (10781) 1 TB USB 2.0 HDD is not recognised as a suitable HDD, so you cannot set up HDD recording (10621) Timer recordings overlap - even when planned for different days (11452) No teletext on SRF1 HD and RTS UN HD (11488) Missing N.RADIO station NRK P13 (11509) Crash/slow when stepping in programs (11512) No sound in the internal speakers (11513) No TV tuner picture when exiting HbbTV video with red button (11600) The TV re-boots/switches off without curtains every time a sound set-up is stored (11879) Time-out for N.RADIO is too small causing Avant N.RADIO Connection Error message (11892) Very short interruptions of Internet radio every few minutes on all channels. Sound drop-out on sw 1.0.8 (11894) Intermittently does not switch on/show picture or sound from standby. After a mains reset it has picture and sound (12243) 21. BVA-55 When selecting N.RADIO, the unit seems to have problems with buffering and, in most cases, it crashes/freezes (12301) Cause New functionality and error correction Solution Update to version 1.0.10.37040 Please remember to keep yourself updated with the Registered Quality Problems! Compatibility All BeoPlay V1, BeoVision 11, BeoSystem 4 and BeoVision Avant can be updated with the new version.
Livingroom: BL3, BL11, BV11-46 Kitchen: Beosound 1 GVA, Beocom 2 Bathroom: M3 Homeoffice: M3, Beocom 2 Library: Beosound Emerge, Beocom 6000 Bedroom: M5, Essence remote Travel: Beoplay E8 2.0, Beoplay EQ, Beoplay Earset
Michael:Really? Sounds strange but I might look into it. I have the same delay on both my V1 and my Avant.
Seems a bit odd but I can try. But you say Foxtel, and this is an Apple TV :).
Aussie Michael: He came back 10 mins later and said he got a call and because the b&o IR is so strong it has to be offset. He fixed it and boom! It worked :-)
This is a 'fix' known by many B&O installers.
beolion:How do you adjust the strength of the ir on the remotes?
Sadly high quality (high bitrate) mkv-files still lag on my Avant. And the strangest thing is that they play back perfectly on my V1. Perhaps the 4K-engine takes CPU power away from the media decoder? Whatever it is it is in the TV. I have been using two different server softwares and it is the same.
BeoFantast:21. BVA-55 When selecting N.RADIO, the unit seems to have problems with buffering and, in most cases, it crashes/freezes (12301)
I had this issue and when i powered on the NetRadio this morning to listen to Abalone it was all good. It appeared straight away - no lag, no buffering issues.
yay
The backlight has been modified so it works much, much better when using for example web radio. When you see meta data on the right and nothing more it is very much blacker around now than before. Seems to me it is very improved.
One thing I would like B&O to contemplate is having the backlight dim out when you turn the TV off, as it closes the virtual blinds. That way it would turn off much more graceful than it does right now. Since the backlight might be very bright when you look at a bright source, the curtains will be grey until they close completely and then it turns black in a blink. Having it fade down the backlight at the same time the sound fades out and the curtains comes together would be a much more magical experience.
Michael: One thing I would like B&O to contemplate is having the backlight dim out when you turn the TV off, as it closes the virtual blinds. That way it would turn off much more graceful than it does right now. Since the backlight might be very bright when you look at a bright source, the curtains will be grey until they close completely and then it turns black in a blink. Having it fade down the backlight at the same time the sound fades out and the curtains comes together would be a much more magical experience.
That's a good point - and should not be hard to realize.
