Bang & Olufsen Beolink Multiroom launched
This post has 51 Replies | 7 Followers
Carolpa
Posts 1,700
Silver Member
Carolpa replied on Tue, Aug 11 2015 6:26 PM
@ beojeff
just some thoughts on your hypothetical system.
you cannot assigns two times the same ML command to different sources
there are a limited amount of ML sources to be programming in the BLC
to control 2 ML masters you must have a NL BV in between in my opinion; are 2 BLC a NL setup?
to connect the BS4500 to a BLC why not use a Beolink converter T1611.
Carolpa
Posts 1,700
Silver Member
double
beojeff
USA
Posts 2,012
beojeff replied on Tue, Aug 11 2015 9:02 PM
Carolpa:
@ beojeff
Indeed, a Beolink Converter Type 1611 is what I was referencing -- used to connect ML and MCL. It's a bit confusing with the "new" converter also being called a Beolink Converter. What you said makes sense -- that you just do a source map on one BLC. Perhaps then, the 2nd BLC would just send that same source command as mapped on the NL side from the 1st BLC over to ML on the other side of the 2nd BLC.
mr_anders_son
sweden
Posts 1,710
Can this works?
BV11-55 ------ NL/ML Conv -----BS9000 ------ BV6-26----- BV7-32
Can I use Beomusic app?
BeoVision Haermony 65"...BeoLab 28 Anthracite....BeoLab 17 as REAR....BV10-32....BC6-26....Beosound 9000....Beosound 1 New York edt....Beogram 4002....Beoplay Emerge....Beoplay M5....Beoplay M3....Beoremote Halo....BeoRemote One BT....Beo6....Beo4....Beo4 Cinema....BeoLink 7000....Serene....H95 Black LTD....H9i Rimowa....6 x H6....Form 1....U70...
stijndc
Mechelen - Belgium
Posts 35
stijndc replied on Sun, Aug 16 2015 11:56 AM
mr_anders_son:
Can this works?
No you need Essence, Moment or Beoplay A9 to use the Beomusic app
mr_anders_son
sweden
Posts 1,710
stijndc:
But my Bv11 is a NL product!?
Flere
Netherlands
Posts 345
Flere replied on Sun, Aug 16 2015 4:34 PM
Sadly B&O did not yet release BeoMusic app support in the Avant or 11.
And I do not know if they ever will.
- Flere
smile and enjoy the moment
mr_anders_son
sweden
Posts 1,710
Says so on B&O site
Flere
Netherlands
Posts 345
Flere replied on Sun, Aug 16 2015 5:36 PM
Well, on the bottom of the B&O music app page it says you need at least one of
Moment
Essence
A9
To be able to use the music app.
So although the BVA or BV11 are NL products they do not act as a master for the music app.
- Flere
petrosbeli
Posts 64
The BeoMusic app requires one of the new audio products (BeoSound Moment, BeoSound Essence or BeoPlay A9) to be present in order to be activated.
The BeoMusic page shows the supported products, for the app to function: http://www.bang-olufsen.com/beomusic
If other NL products (e.g. BeoVision 11, BeoVision Avant) are in the system, they can be controlled as part of the multiroom offering, but to a more limited extend (e.g. you can distribute sound to them, but you cannot fully control their sources). However, the requirement is that one of the previously mentioned audio products is available, for the activation of the app.
This is done due to a combination of technical and commercial/licensing reasons. I hope this clarifies.
Petros
mr_anders_son
sweden
Posts 1,710
Ok thanx!
If I have NL/ML conv. I connected it to my ML.
My BV 11-55 is connected wireless to my network.
So can I connect the converter direct to my router or must I connected it to BV11 with a cable?
Millemissen
Flensborg, Denmark
Posts 14,680
The BV11 and the Converter must be on the same network.
In your case connected to your router.
The BV11 may be connected wirelessly, the Converter can inly be wired.
Page 2 of 2 (52 items) < Previous 1 2 | RSS
