Aussie Michael:Unrelated question: Is the A9 90 year edition a Mk2?
BeoNut since '75
Am I the only one who has the problem with Deezer in the App?
It won't register me as a Premium member, so when I use the BeoMusic App I can only play 30 seconds clip?
elephant: Aussie Michael: Unrelated question: Is the A9 90 year edition a Mk2? One would hope so !
One would hope so !
Yes it is, I have it.
I have now updated the BeoMusic app, but i can not open it.. It want even start on my iPhone 6.
Anyone else has the same problem?
I have deleted the app and installed it again, but the same problem...
Your dealer is correct. Spotify can be distributed, among NL products that support Spotify Connect. See screens below:
1. You start, via the Spotiy App, playing to one of the Spofity Connect products
2. Via the BeoMusic App, you can expand to other products
3. Even the UI of the Spotify App is updated, and it shows that the two (or more) Spotify Connect products are now grouped in a multiroom session
Petros
petrosbeli:3. Even the UI of the Spotify App is updated, and it shows that the two (or more) Spotify Connect products are now grouped in a multiroom session
Yes, cool indeed - maybe I could use another Essence..
Dave Farr:Try a hard shut down of the phone and restart it. I had a problem between Essence and other apps and a restart of the IOS device fixed it. Dave.
Dave.
Hi.
What do you mean by hard shut down? I have tried to restart it, but same problem.. Really strange ...
@petrosbeli
Thanks!
Shut the phone down and do the restart so that you get the Apple logo at the restart.. 2 buttones to close the phone down etc. Or whatever it takes for your iPhone.
It now works when i am not connected to wifi, but as soon as i connect it's fails!
I speak to my dealer today and it seems to be a bug in the BeoMusic software.. The problem is that it wan't at work with Norwegian text using my iPhone 6, so when i switch to example Danish, everything woks fine..
But should't i also se my BLC on the App?
Normann:I speak to my dealer today and it seems to be a bug in the BeoMusic software.. The problem is that it wan't at work with Norwegian text using my iPhone 6, so when i switch to example Danish, everything woks fine..
OMG a racist software bug! What a bizarre thing to find out. I hope they can fix that in an upcoming update. How's your Danish?
It'så almost the same as Norwegian, so i Can handel it for some days ;)
BeoMusic v.2.0.1 was just released to the App Store, and it fixes the issue with the Norwegian language.
petrosbeli: BeoMusic v.2.0.1 was just released to the App Store, and it fixes the issue with the Norwegian language. Petros
JIPPi :)
tradingman:Good Morning, Is it possible to use the MK2 with the external IR-Receiver and the new Beoremote One? MK1 only works with the old Beo4 - as the B&O FAQ says.... Regards
elephant:Back to the thread's title ... Mine has arrived and is waiting for me ... By the end of the weekend I may have some answers for you ! BeoNut since '75
Mr Elephant congrats to you.
I want !!! with pictures if possible
"Believe nothing you read and only half of what you see, let your ears tell you the truth."
elephant:Now the fun begins ... Who wants an unpacking thread ? BeoNut since '75
Go for it !
I'd like it please, and also, this is as many boxes as there was for the BS5 Encore :-)
