BM4400 Basket Case
This post has 98 Replies | 2 Followers
Craig
Yarm, United Kingdom
Posts 2,040
Silver Member
Martin...unfortunately I had picked up on this crossover, OIC100/101 are BCE and OIC102/102 are BEC. Checked them out non the less and all is well, however as an aside as I was re testing TR115 I noticed what I suspect is the rougue diode which doesn't appear on the schematic....looks like D106 and is connected from the collector of TR115, on the solder side, to the collector of OIC100....see below pictures.
Craig
Posts 2,040
Silver Member
marked up schematic......
Craig
Posts 2,040
Silver Member
oops....sack the above, it's actually the emitter of 0IC100 and the collector of 0IC101
Craig
Posts 2,040
Silver Member
Craig replied on Sun, Jan 29 2017 6:20 PM
Well......following the removal ant testing of all the transistors and diodes in what was a monumental push I still couldn't find a failed component! in despair I powered up and was delighted to see the fault relay idle....connecting up a speaker to both channels and selecting FM I was rewarded with a crisp and clear signal from both speakers.......I don't know which component was giving me all this grief, dry joint or open circuit, but clearly (as Martin predicted) it was something of the that order, Martin......your a star, your support is invaluable.
Still got a bit to do...set up the quiet quiescent current.....box it all up and sit back for a good listen ;¬)
Craig
Posts 2,040
Silver Member
Picture of the repair to the cracked track on the solder side, will be epoxy fixing a piece of old circuit board (if I can find a bit) on the top side to add mechanical strenth to the repair, not a very sharp image i'm afraid.
Craig
Posts 2,040
Silver Member
Set the quiet current to the prescribed 5.6mV........
Craig
Posts 2,040
Silver Member
fitted a support over the cracked section of PCB with the help of epoxy glue, not sure how the boys ad Dell would view the destruction of one of their graphic cards....but hey...needs must when the devil drives ;¬)
marc
netherlands
Posts 78
marc replied on Mon, Jan 30 2017 8:13 PM
That piece of graphic card is in a better place now!
priklep
Slovakia
Posts 103
priklep replied on Mon, Jan 30 2017 9:07 PM
Dear Craig,
I am  constantly watching your progress with interest . I have no electrical skills, so it is for me this is Confused. Do no give up, new BM wooden cabinet is beautiful. I am listening my BM4400 now, it is worth  to do it.
ALF
AUS
Posts 1,015
Silver Member
ALF replied on Tue, Jan 31 2017 1:41 AM
I just had my last delivery from RS !!
Never again - delayed deliveries, faulty parts, parts missing, charged premiun prices......for what ?
Spending $$$ dialing 1300xxxx numbers.......no thanks :-):-)
ALF
beo3000
Posts 109
beo3000 replied on Tue, Jan 31 2017 12:35 PM
RS must be different in Australia in the UK they are very good especially if you only want couple of pound worth of stuff as its all free next day delivery
some things are cheaper there as well altho a lot is more expensive.
Craig
Posts 2,040
Silver Member
Pretty much at the end game now.....refitting the screen inside the top cover......
Craig
Posts 2,040
Silver Member
Closed up and back in service....you all know how good these sound, I'm not entirely convinced about the finish.....it looks so much different from the norm that is bordering on strange, none the less it's been an entertaining journey......
Craig
Posts 2,040
Silver Member
Couldn't get rid if the ding in the front after all...........
Craig
Posts 2,040
Silver Member
I also need to address a minor issue with one of the retaining machine screws at the rear.....the thread is stripped and will need to be tapped out oversize and a new screw fitting
  • Filed under:
Craig
Posts 2,040
Silver Member
last one....
beo3000
Posts 109
beo3000 replied on Tue, Jan 31 2017 8:01 PM
looks great now you need to find a beogram with a scruffy plinth and make one to match
Saint Beogrowler
Saint Paul
Posts 780
I've been looking forward to these pictures for a while! I think it looks great but maybe it would look even better on Beomaster 4000 with the dark face to contrast...
Hmmm.
What kind of veneer do you think you will try for your next basket case?
ALF
AUS
Posts 1,015
Silver Member
ALF replied on Thu, Feb 2 2017 5:38 AM
That may well be the case in the UK :-):-) lucky you !!
I waited for some wire-wound resistors for over 2 weeks only to find out during the wait they were actually coming from their uk-warehouse:-)
And then their policy of selling 10 or 25 parts if you only require 2.......yes, that is not always the case
But more often than not.
So, I definitely said 'good bye' to RS.
ALF
Page 3 of 3 (99 items) < Previous 1 2 3 | RSS
