Which button on the Beolab 2000 you press in order to join the Airplay source?
stampfki: Which button on the Beolab 2000 you press in order to join the Airplay source?
Since the NL/ML Converter is involved there, it depends on how the (AirPlay) source is mapped there.
depending of the converter´s set-up you can change the frontbuttons. in my set-up e.g. the Radio- and the CD-button remain on the BeoSound 3000 and the TV-button triggers TuneIn from the BS 35. AirPlay is not a source one could choose in the set-up. So you have to push the Play-button on the side to join AirPlay. Have fun!
Wohnzimmer: BeoVision Avant 55", BeoLab 11, 12-2 und 12-3 für 5.1-Sound + appleTV 4K und Philips BluRay-Player; BeoSound 2, BeoSound 3000 (fast nur noch Deko)////Schlafzimmer: BeoEssence MkII, BeoLab 4000 + Samsung 46"-TV////Büro: BLC NL/ML, BeoSound 35, Thorens TD320MkII, Samsung 32"-TV, WesternDigital 4TB-Server////Bad: BeoLab 2000; alles CAT7 verkabelt////Küche: M5 (drahtlos) plus diverse apple-Geräte (imac, macbook, ipads, iphones, timecapsule, watch)
