Peters Beolab 5000
This post has 34 Replies | 0 Followers
Craig
Yarm, United Kingdom
Posts 2,040
Silver Member
Craig Posted: Mon, Jul 9 2018 6:07 AM
A new challange has been thrown down at the weekend! symptoms are channel fading on one side.....will get the manual out and read up..........
Craig
Posts 2,040
Silver Member
Ok....getting back to this one now Roasties BG4000 has been dispatched, connected my Ipad up to the AUX input and played a tune....got a very poor weak sound from the speaker 2 outputs....bit concerned I plugged the Ipad into the TAPE input and the sound reproduction is very good. Cant detect any fading from either channel...in fact it sounds very nice. will try speaker 1 outputs with a centre speaker too and see how that goes.....not sure why the AUX input isn't happy with the Ipad…..
Peter
Earsdon
Posts 11,991
Peter replied on Wed, Aug 29 2018 8:44 PM
This is the Beolab 5000 that Frede restored for me in 2008. Been serving up sterling work for some time now but suddenly developed a fault - may well be the Aux in...
Peter
Craig
Posts 2,040
Silver Member
Craig replied on Wed, Aug 29 2018 8:52 PM
Peter
Was over in your neck of the woods last weekend, drove right past Earsdon on my way to a wedding in Whitley Bay......lovely place ;¬)
  • Filed under:
Peter
Earsdon
Posts 11,991
Peter replied on Thu, Aug 30 2018 9:20 AM
You should have popped in! I could have given you another VCR ! Have a wonderful V2000 model looking for a home!
Peter
Craig
Posts 2,040
Silver Member
popped the top off for a look inside, bit dusty but otherwise in very good shape....all previously recapped. Power supply, Driver Stage Left and Right
Craig
Posts 2,040
Silver Member
Pre Amps, Amps II, Tone Control Amps left & Right.
Craig
Posts 2,040
Silver Member
Pushbuttons, Filters,more Amps and Level Control.....
Craig
Posts 2,040
Silver Member
Craig replied on Thu, Aug 30 2018 8:02 PM
Very compact in there....will give it a clean and make a start tracing a signal through the AUX input, see how it looks
Søren Mexico
Mexico City
Posts 6,411
Interesting seeing a unit from Classic Audio from the inside, check the switches, I had to clean the switches various times on the 2 units I restored
Søren Mexico
Mexico City
Posts 6,411
It looks like Frede put some extra protection over the switch assembly
Søren Mexico
Mexico City
Posts 6,411
Pic from my first one, observe the switches, no cover
Craig
Posts 2,040
Silver Member
Cant say I see the covers you refer to Soren...is it that the switch sliders on Peters Machine are grey in colour as opposed to black?
Craig
Posts 2,040
Silver Member
Ok....looking at the service manual it tells me that the AUX input and the PHONO input on HIGH impedance setting both take the same path into the amplification sections.
Craig
Posts 2,040
Silver Member
Craig replied on Fri, Aug 31 2018 5:39 PM
Poor image...sorry, however when I connect my iPAD to the PHONO on HIGH impedance I get a nice mellow sound from the amp....connecting back to the AUX and I'm getting almost nothing.....I'm thinking that the problem is narrowed down to the AUX socket or as Soren advises the selector switches. I think its time to employ the faithful old scope yet again.....£20 from ebay a couple of years ago, what a good buy its turned out to be ;¬)
Søren Mexico
Mexico City
Posts 6,411
Craig:
Yes it must be gray switch sliders, in the 2 units I have seen they are black
Craig
Posts 2,040
Silver Member
Found something a little odd....when injecting a 4khz signal through PHONO set HIGH the signal at the AMP II input to the base of the first transistor (no tag identifiers on the components in this machine) was very clean, injected the same signal using AUX input and got nothing at the same transistor base...took a look at the 5 pin DIN plugs and found the PHONO is wired across pins 2/5/3......PHONO socket is second from the left in the pic with the grey/white connections.
Craig
Posts 2,040
Silver Member
However.....the AUX connections are wired to terminals 1/2/4 of the 5 pin DIN socket, 4th from left with the yellow/white wiring, so clearly the 5 pin DIN plug I'm using to connect to the AUX isn't wired up in sync with this socket, but its good for the PHONO......
Craig
Posts 2,040
Silver Member
This is perfectly correct according to the service manual...….but how odd, is there a reason for this? cant see the boys at B&O doing this just for the hell of it.....I will the AUX in accordance with the PHONO socket for testing purposes and leave it like that unless anyone can explain why this should be so?
Craig
Posts 2,040
Silver Member
Connected my signal generator directly into the AUX phono jacks that sit above the 5 pin DIN, injected 4khz at 1v pp and got a sweet output on both channels....next step will be to have a look at the signals coming out of each chanel for signs of distortion/clipping.....see if anything is amis.
Craig
Posts 2,040
Silver Member
had these little fellows delivered this morning....
Craig
Posts 2,040
Silver Member
so promptly removed the front and all the switch buttons to expose the slide potentiometers, bit dusty as you would expect so some cleaning to be done before application of the two greases.
Craig
Posts 2,040
Silver Member
unfortunately I will be flying off tomorrow, I can be found windsurfing off the coast of Greece by day....and in the bars and restaurants of Vasiliki by night! tough life I know......any hints or tips would be nice to read up on my return, may even drop in occasionally over the next two weeks whilst sipping cold beer at the beach bar ;¬)
Peter
Earsdon
Posts 11,991
Peter replied on Sat, Sep 8 2018 8:05 PM
Have a wonderful time - hope the weather is kind to you!
Peter
Craig
Posts 2,040
Silver Member
Following a very hard two weeks on the water I'm back, I keep telling myself this will be the last time I go windsurfing....but my partner is now getting very good at it and I fear I may have created a monster! not to worry....got the slider tracks lubricated with graphite grease and the guide rods given a coat of silicon grease. Started to reassemble by reconnecting the sliders to the front frame....been a few weeks since I disassembled this so some care will be required.
Søren Mexico
Mexico City
Posts 6,411
Welcome back, is it true that windsurfing cures the Beovirus ?
Craig
Posts 2,040
Silver Member
Craig replied on Wed, Sep 26 2018 9:21 AM
Cheers Soren.....however I dont think there is a cure for our particular ailment ;¬)
Craig
Posts 2,040
Silver Member
front panel re assembled complete with slider cursers and pushbuttons, powered up and time to check the no load current. It is in remarkably good condition, I have been reading Sorens thread and there is no comparison between the condition of Peters machine and that of the machine Soren restored when he first took delivery.
Craig
Posts 2,040
Silver Member
Following the application of the silicone grease on the slider pot guide posts the cursers move more slowly to the touch and feel somehow more stable, more precise if that makes any sense.
Craig
Posts 2,040
Silver Member
Left stage measures up pretty good at 6.2mV across R460
Craig
Posts 2,040
Silver Member
Right stage looked a little high at 7.5mV
Craig
Posts 2,040
Silver Member
Tweeked it down a little...……...
Craig
Posts 2,040
Silver Member
Right symmetry voltage...looks good
Craig
Posts 2,040
Silver Member
Left symmetry also looking good....and quite frankly it all sounds very good too, cant really find anything amis with this amp.....it sounds great!
Craig
Posts 2,040
Silver Member
Craig replied on Mon, Oct 1 2018 8:42 PM
Well Peter...if it isn't broke don't fix it, I'm just going to box her up and enjoy her until your down this way again to collect.....there's no rush ;¬)
Craig
Craig
Posts 2,040
Silver Member
Craig
Posts 2,040
Silver Member
Peter
Earsdon
Posts 11,991
Peter
Craig
Posts 2,040
Silver Member
Peter
  • Filed under:
Peter
Earsdon
Posts 11,991
Peter
Craig
Posts 2,040
Silver Member
Craig
Posts 2,040
Silver Member
Craig
Posts 2,040
Silver Member
Craig
Posts 2,040
Silver Member
Søren Mexico
Mexico City
Posts 6,411
Søren Mexico
Mexico City
Posts 6,411
Søren Mexico
Mexico City
Posts 6,411
Craig
Posts 2,040
Silver Member
Craig
Posts 2,040
Silver Member
Craig
Posts 2,040
Silver Member
Søren Mexico
Mexico City
Posts 6,411
Craig:
Craig
Posts 2,040
Silver Member
Craig
Posts 2,040
Silver Member
Craig
Posts 2,040
Silver Member
Craig
Posts 2,040
Silver Member
Craig
Posts 2,040
Silver Member
Craig
Posts 2,040
Silver Member
Craig
Posts 2,040
Silver Member
Peter
Earsdon
Posts 11,991
Peter
Craig
Posts 2,040
Silver Member
Søren Mexico
Mexico City
Posts 6,411
Craig
Posts 2,040
Silver Member
Craig
Posts 2,040
Silver Member
Craig
Posts 2,040
Silver Member
Craig
Posts 2,040
Silver Member
Craig
Posts 2,040
Silver Member
Craig
Posts 2,040
Silver Member
Craig
Posts 2,040
Silver Member
Craig
Posts 2,040
Silver Member
Craig
Posts 2,040
Silver Member
Craig
Page 1 of 1 (35 items) | RSS
