And all done. The pointer light looks better (and brighter) than it does in the photo.
Just loving that B&O FM sound...
Great repair. May I ask where you got the dpf with the schematics? I can't seem to fint any with good enough resolution to be able to read the values on the components.
Hi Caladan,
The service information is available on this site for download if you are a silver or gold member.
As component values are sometimes at variance with the schematic, you might want to cross check with the actual values in the unit you have.
Krolroger
