Yes, I have a matrixes feeding 2 BVs.
Expensive but very tidy solution.
Michael: Sandyb: Correct, only 1 output. hm I might remember wrongly but there is a solution setup for this kind of solution with Atlona or something at least. I know there is an implementation for the use of a projector in combination with a monitor in beosystem 4, but agreed beosystem 3 is much easier to configure for this. Same goes for some beovision 7 that has an output for a projector via hdmi and a rs232 port for control of it. So it was very widely adopted in the Beovision assortment for many years.
matador43: "Press Pause and Play", that one was very nicely done.
That one is too,
https://youtu.be/-ecSYXkRf6M
Of course when you know the price tag, it works a little less and It also implies that you can dust off any 4000 from the attic and get it back brand new.But all in all I think its finely done, in the details, the story, the cinematography and moreover the cast.
It worked very well on me at least!
